Kuat or Thule bike tray rack on NAS 90? - Defender Source
Old June 5th, 2016, 06:57 AM
vtlandrover
Frank
1991 200Tdi 110 Hicap
I'm sick of roof mounted bike racks - and my receiver-hitch hanging style causes my 29er to swing around like crazy on our dirt roads. No amount of strapping seems to stop it.
I looked at the new Thule T2, but can't put it in the stowed position because of the spare tire. Adding a Class III receiver's an option, but defeats the anti-vibration design. This is especially true since carrying the weight even further out will most certainly cause it to move around.
Wondering if anyone is able to run a tray-style hitch mount rack? If so, what brand??
Old June 5th, 2016, 09:05 AM
bjf's Avatar
bjf
barry f
94 ST #395
I have a t2 on my 90 with a hitch extender and it seems solid but I have not driven down any dirt roads with it. I have used the t2 on my lr4 and driven down dirt roads and it bounces around a bit. Not sure you can avoid it.
Old June 5th, 2016, 09:53 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Does your rack and hitch extender have pins or bolts? I have an old SportsRack (Thule bought them out) and it has a nut on the inside that when tightened it doesn't move. There is play on the tray section where it folds up but not that bad.
Next time you are in Stowe see Paul and those guys at iRide - they might have some good ideas on how to beef up the hitch mount or what rack works best.
Old June 5th, 2016, 10:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
My extender and he rack both have bolts. Pins would bounce everywhere.
Old June 5th, 2016, 02:46 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Maybe that's what he has and is the issue?
Old June 5th, 2016, 04:25 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I have the exact setup (though sometimes I switch it to four bikes) and it works really well. You still get some flex and bouncing but it isn't that bad. It does screw with your departure angle of course.
Old June 5th, 2016, 04:56 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I have a Kuat NV 4 bike rack- damn that thing is heavy.
Works well and doesn't sway on my LR3, RRC,or 110. But, on the 110, 1st bike gets close to the spare tire/wheel and pedal placement becomes an issue.
Additionally, the rack wont fold up on the Defender. I haven't needed to as I usually take the rack out when I get home, but I could add an extension with a bolt. The 2x I have chosen to fold it up so it's less obtrusive at the trail head, I would run the cable lock through the spare.
Email is
Same place, new dogs.
Old June 5th, 2016, 05:03 PM
vtlandrover
Frank
Did some research today and found that there are shorter receiver extensions (7") available as well as anti-wabble locking pins. This solves my concern - being able to lock the rack to the Defender. Unfortunately, its become common around here for dirtbags to rob cars parked at trail heads... two friends have been ripped off separately at pretty popular parking areas.
I also learned that Kuat has a lightweight (32 lbs) rack that just got released last month called the "Sherpa 2.0." Going to look into that tomorrow and will report results. The internet has conflicting info: one site says you can't fit a fat bike, another says you can... thinking with the winters we've been having, I may become a year-round rider yet.
Can't bring myself to end my post with a frown.
Old June 5th, 2016, 10:15 PM
LR Max
Thomason, Max
1973 Series 3 109
I have a Kuat The NV. It is pretty much the bestest bike rack ever. Mainly, I use it on my hatchback. The biggest issue is that my hitch is attached to my unibody...and it flexes. But I think on a solid hitch mounted to a solid chassis, it won't move.
I've got an adapter to go from the 1.25" to a 2" to use with my rover. Now that the rover actually works, I'd like to start using the Kuat on the rover.
But yes...it is lovely.
Old June 6th, 2016, 12:23 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
T2 with jsq hitch mount. Amazon anti vibration device. Works awesome
Old June 6th, 2016, 01:23 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
There is no better rock than one of these
North Shore Bike Racks
SOLID.. and hand built just down the street from me. No rattle, no swaying, (even hit the odd speed bump doing well, more than I should) no problems at all. The rack is solid in the receiver mount, and the bikes are solid on the rack.
They make them in 2, 4 or 6 bike configurations.
Old June 6th, 2016, 05:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
I used the 7 inch extender with the thule locks. I like thule as it has bike cable locks built in. Also thule sells every part for it which has come in handy.
With the 7 inch extender it will fold up on a 90 fine.
https://www.instagram.com/p/VIAnF3jh...n-by=bfein1075
Old June 7th, 2016, 12:36 AM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
Just weld an extension on the bike rack.
Old June 7th, 2016, 06:13 AM
vtlandrover
Frank
Andrew - you can't weld an extension. The cool thing about these new bike racks is they've removed 1/4 of the receiver tubing (the top and one side) and integrate an aluminum shoulder that adjusts... turn a knob and the shoulder compresses out against the inside of the vehicle's receiver hitch. Voila! No more movement. My concern all along has been that adding an extension will delete that benefit - but I'm told there are hitch pins that produce similar anti-wobble/vibration results. Have to just order one and see...
Old June 7th, 2016, 11:55 AM
Chip's Avatar
Chip
Andrew
That's cool. I have a Thule Parkway bike rack we cut and welded in an extension. I'm sure it's not the best bike rack, but I got it really cheap at one of REI's used gear sales. It was new though. I think someone returned it because it had a gob of weld in the securing nut. Just had to tap it out.
Old June 7th, 2016, 12:57 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by CDN38 View Post
There is no better rock than one of these North Shore Bike Racks SOLID.. and hand built just down the street from me. No rattle, no swaying, (even hit the odd speed bump doing well, more than I should) no problems at all. The rack is solid in the receiver mount, and the bikes are solid on the rack. They make them in 2, 4 or 6 bike configurations.
These look sweet!
You guys do a lot of shuttling on Class 4 roads so I bet these get put to the paces.
Crazy how simple the racks are and how they can fit so many different types of bikes.
Old June 9th, 2016, 09:37 AM
LR Max
Thomason, Max
1973 Series 3 109
Question: What is the Anti-Vibration device you speak of?
90, ac, nas, rack
Thule 964 Revolver Hitch Bike Rack Bill Larson For Sale - Parts 3 May 15th, 2015 10:40 PM
Thule Bike Rack bjf Defender Technical Discussions 31 April 23rd, 2010 12:05 AM
Thule Bike Carrier that mounts on spare tire evilfij For Sale - Parts 6 December 29th, 2009 02:50 PM
Thule sidearm - single tray bike carrier snosrfr For Sale - Parts 7 May 18th, 2007 09:24 AM
Thule swing away bike rack FS DaveG For Sale - Parts 2 July 7th, 2006 01:12 PM
