Karoshi suicide salaryman. - Defender Source
Old April 6th, 2010, 03:45 PM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Start on level 49 and work down to level 1. Some took me several tries.
http://www.addictinggames.com/karosh...salaryman.html
Old May 24th, 2010, 01:50 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
Nice! But I cant get past level 7
Old June 1st, 2010, 03:33 PM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Move over one block and hit the letter K on your keyboard.
Old June 6th, 2010, 06:44 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
How about level 34? I just can't get past it.
Old June 7th, 2010, 09:30 AM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Push the block on the bottom to the left so you can jump up to the upper level. Push the top block over so it falls on the other one. Jump back down to the original block and push it all the way to the right so when you flip the swithc, the three blocks will fall and stack up on each other. Take the top block and push it over the swithc then use it to jump back over the wall. Then jump yo' ass on the lightning bolts.
Old June 7th, 2010, 06:51 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
I knew that, I ment level 32
Old June 8th, 2010, 09:25 AM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Push the safe over so the danger box falls. Push the danger box over the last lightning bolt box on the right. Slide the safe back to the left up against the danger box. Jump down to the right without touching the red button. Walk over the switch and stop under the box. The danger box will blow up and push the safe over the red button...dropping the other box on your head. That one took me a few tries too.
Suicide by Navy Destroyer? phoenix37 Misc. Chit-Chat 3 April 1st, 2010 03:31 PM
