Just one axle, no engine and ist's from the island: something about Sankey trailers - Defender Source
Old July 28th, 2014, 05:00 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Just beyond the bottom line:
It's called that the British Army had been called an Indian scrap dealer to get it all.
Including the spare parts!
Well, I really don't know about this.
But needed spare parts are not available.
Nevertheless, I like these trailers!
This is what you get:
Narrow track about 1968
a little bit corrosion here ...
... and there.
It'll take some hours to get it shiny!
Or something like that:
Wide track 1986
kitchen work was dismanteled. It wasn't ready to go bacause one of the wheels doesn't move.
Found this remaining ruin offered on ebay in 2007 for 200€ and bought it, dismanteled it, towed it by Sankey #I back from Cologne to Bremen...
But let's have a look step by step.
If you would like it?
Old July 28th, 2014, 05:40 PM
Yes please
Originally Posted by pendy
I'm here for the D's
Old July 28th, 2014, 06:43 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
Oh man this is going to be exciting!! I like the trailer threads.
Old July 30th, 2014, 04:56 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Ok then, here we go:
At the end of all I got this German title
My first one was a 1968 narrow track Sankey. I just wanted one. Didn't know about the secrets about it, so I tried to dismantle my new buddy first.
Well, I cracked some bolts.
Got exausted about the waterproof electric lines...
... and the mechanical parts inside.
Amazing stuff!
This is good for another 100 years!
The tub is definately not made for this time!
It is original welded of steel but over the time totaly corroded to huge holes, several times rewelded and at the end of that bend at its bottom.
Don't liked it any more.
I cut the upper rail and the inner wheel housing out and welded it to an inner subframe.
All of this got zinc plated.
I just got a nice little helper!
Sold in 2011
Old July 30th, 2014, 05:55 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Trailer tent
Number two needs a special body's hight to fit the trailer tent!
Ten years after I thought about paint.
I gues it was just in time!
Old July 31st, 2014, 03:34 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
My first Wide Track Sankey (MkII)
In 2007 I bought the complete frame of former kitchen unit. Used the narrow track to do the transport from Cologne to Bremen.
The plan was to put the tub from the 130 onto this frame.
Big surprise when downloading this peace of heavyness: it's way heavy!
Last year, when I restaurated another wide track for a good friend, I thought about of an unit to carry the frame and the possibility to turn it over and over again without thinking about the bad hurting back.
It's useful!
How I made it:
I would like to say it's a must have!!!
To match a narrow track frame this adopter is necessary:
Old July 31st, 2014, 03:42 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Sooooo you opening up shop stateside soon? Because I think I speak for everyone when I say,
Your piece of dirt looks like a fab wonderland!
Old July 31st, 2014, 03:56 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Another useful tool to handle the axle in a vice, on a box lifter or in a floor lifter. The axle is heavy to!
------ Follow up post added July 31st, 2014 02:03 PM ------
Thanks Jason!
I don't have a green card.
Might be Uncle Doug will employ me?
Old July 31st, 2014, 05:17 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Troubleshooting if enything went wrong
Corroded bolts
They usualy brake.
Try to get a mixture of Acetone and ATF to the corroded parts before trying to get them loose!
It works very well. But it will take some time! And you should do it more than once!
Corroded bolts inside the shakles / springs
No way out. Take a saw!
Afterwards drive the bush out and use a lathe and coolant stuff!
I reame the bore to 16H7 to match a M16x1,5 bolt. Easy to get them in Europe!
The original thread 5/8"UNF is changed to M16x1,5 too.
The shortened inner bush needs a small distance. Shown up on the left side.
Old July 31st, 2014, 09:47 PM
Why don't all floor jacks have an axle attachment like that? It makes so much sense!
Old July 31st, 2014, 10:24 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Very Nice work.
Would like to see some clear more detailed pictures of your Sanky camp trailer sporting the roof top tent.
RDavisinVA
Old August 3rd, 2014, 06:21 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I don't now.
Just do it!
------ Follow up post added August 3rd, 2014 04:30 PM ------
Originally Posted by rdavisinva View Post
Very Nice work.
Would like to see some clear more detailed pictures of your Sankey camp trailer sporting the roof top tent.
Please have a look at http://www.howlingmoon.co.za/shop/te...er-tent-olive/
I just created the distance between the frame of the Sankey and the bottum of the tent!
Old August 5th, 2014, 05:10 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
To support a straight axle it's an easy job to do.
Axles with a differential gear box inside will need a cranked supporting helper.
Thaught about this too. Easy to lift the vehicle at the front or rear by floor lifters.
But it's a smart difference betwenn lifting a 250 pound part to the whole vehicle.
So I didn't ponder on that.
Old August 5th, 2014, 05:26 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Very Nice work.
Didn't take many pictures at all.
Old August 5th, 2014, 06:16 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Stoopid handbrake lever
Well, it shows upwards and it's a hindrance to a lid or the rear door.
Just crank it!
The narrow track needs to be cranked twice.
The wide track handbrake lever has enough distance to the overrun unit.
Just one cut is necessary!
Old August 5th, 2014, 08:31 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Absolutely stunning. Awesome work.
Old August 6th, 2014, 03:18 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Different types of overrun units
Springloaded unit, rotating draughteye 360° mostly used on narrow track Sankeys.
Parts
New sealing
New damper and washers
Longer headnuts to protect the long studs
2" nut reduced to match a 50mm spanner
How to handle the spring while reinstalling the dome
Fixed to the trailer
Old August 6th, 2014, 03:39 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Bradley unit, fixed eye, gasspring loaded, fitted to half of the wide track Sankeys
It's hard to get the spring compressed!
Small pin holding the gasspring inside the draught eye
Parts
Reverse stop
Reinstalled to the draughtbar
Old August 6th, 2014, 04:10 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Sacol unit, fixed eye, hydraulic damper, used on the other half of the MkII wide track Sankeys
Renewed item
Main parts
Cylinder removed
Cylinder completed, piston and rod separated
Reverse stop with housing
Sealings (hard to get)
Front cover
Rear parts
Piston with choke
Very special parts to hold the inner parts inside when towing!
Picture out of the parts list
Sorry about the quality of some of my pix.
Old August 6th, 2014, 04:50 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Different types of handbrake assemblies
Narrow track unit
This is not the original version! The handbrake lever stands way straight up in the sky!
My cranked version
The main axle is closed at each end and holds a greasing nippel. This makes sence.
Mounted to the frame
axle, engine
Pile of Sankey trailers atlcruiser The Vendors Loft 136 March 10th, 2015 11:47 AM
Sankey Wide Track trailers globallandrovers For Sale - Vehicles 11 September 1st, 2010 11:01 PM
Sankey Trailers ajh For Sale - Vehicles 5 May 7th, 2010 08:20 AM
Check Enginge light and Gas Cap floyd650 Defender Technical Discussions 13 December 27th, 2007 05:44 AM
Sankey Land Rover trailers. Ex-British Army AUSTINSJEEP For Sale - Vehicles 0 November 28th, 2007 10:05 PM
