Just one axle, no engine and ist's from the island: something about Sankey trailers - Page 2 - Defender Source
Old August 6th, 2014, 05:10 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
MkII version
Greasing the axle from the inside
Cranked handbrake lever
Space enough for the lever
Details
Reinstalled
Old August 6th, 2014, 05:50 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Brake linkage
I like stainless steel as well as zink plated steel.
And I like the rear swinging fixing point only used on the narrow track Sankey. This is the reason why I use it on the wide track too.
Parts
Don't like the original knuckle joint. Replaced it by a ball joint.
Another greasing point
New bushes for a hardened axle (signed by hand, I like this details)
New design
Old August 6th, 2014, 06:35 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Hubs and brakes
How it should like to be
Parts shown as they are after several years on duty
Old August 6th, 2014, 07:38 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
To get the parts well done replaced it is necessary to have a look at the inner sealings.
There's a leather outer ring running inside the hub to provide the other one against water and dust. Just like a dust lip. Both are no more available!
Let's have a look at these parts.
Both of the two get dammaged while wrong assembled!
Have a look at these parts.
As shown in my pictures somtimes they are mounted the wrong way. The spring always has to show to the grease!
Zinc plated brake plate
Paper gasket, oil catcher
This centering tool is necessary to provide the hub to get into contact with the oil catcher.
Using socket screws this will be usefull
Inner seal
Setted by the same tool
Backside
Details
Old August 7th, 2014, 04:04 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Brake adjuster parts
Clamped while not fixed
Mechanical brake cylinder
Be sure the grommet finds the groove! Grommets are out of stock.
------ Follow up post added August 7th, 2014 02:14 PM ------
Be sure the brake shoes are in the right position. This shows the left side.
To protect the inner bearing I use my centering tool.
Old August 7th, 2014, 04:45 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Completing the hub
Parts
Cleaned hub
Needed tools
I'm not able to take pix while doing this:
Grease the bearings and the hub.
Fit the hub onto the axle to the inner bearing. Be sure not to distroy the outer leather seal nor the inner one. Take the smooth way and turn the hub.
Hold the hub in place and fit the outer bearing, followed by a washer and the nut.
Titen the nut while rotating the hub. It's well done if the washer is to be displaced by forcing it with a screw driver.
This is necessary to get the play out off the O- mounted tapered bearings.
Followed by the securing washer the second nut is to be fastened ...
... and secured by the securing washer.
Some more grease will do a very good job.
Fit the hub cap with a new paper gasket ...
... and reinstall the drum brake.
That's it in a nutshell.
Old August 7th, 2014, 05:32 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Jockey wheel
The narrow track just has a supporting leg at the front.
All wide tracks (Mk II) have a jockey wheel positioned too close to the rear body!
First of all it has to be mounted on the left side for sure!
Second of all, it has to be turnable as like as the Mk III version!
Here we go:
Yippyyayayippiyippyyeah!
But it's a lot of work to be done for this.
Old August 7th, 2014, 07:10 PM
That could be said for all of your projects! Nice work as always
Old August 8th, 2014, 04:13 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Thanks Jimmy!
Forgot to mention:
This bracket has to be cut off. Be careful. First cut is the deepest!
I use it to cut the new designed bracket out of it.
Springloaded bolt to fix the jockey wheel:
Parts
Assembled ( the holding part has to be welded to the bracket)
After welding these parts ...
... they have to be turned out to a fitting diameter for the bushes!
Old August 8th, 2014, 04:51 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Fitting a 130 tub to a Sankey frame
The inlays of the tub might be looking like that:
left original, right replaced items made of stainless steel
All these parts belong to the rear of the tub.
New fixings to the rear ...
... and both sides.
Overlook:
Welded on
Two rails are supporting the tub too.
Front fixings
Old August 8th, 2014, 05:06 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Tub surgery
------ Follow up post added August 8th, 2014 03:13 PM ------
Special nuts to hold this advertisement part in position:
Old August 8th, 2014, 05:53 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Wirering
I use the 12 pin Nato version!
It's waterproof.
Just running original to the first distributor.
Splitted into two lines the rear lights a serviced.
Just cut the original male pins, drill them out and solder the new line in!
Scenic overview
Details
The original fasteners are mostly corroded. So I put them into a aluminum tub, glued by something the Lord of Darkness never have seen. It works! No corrosion at all.
Please have a look:
Old August 9th, 2014, 03:38 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Some more details:
To connect this huge triangel reflector (it's a must have in Europe) ...
... the rear holder has be cut into halfs! No other way to get it fixed!
But it's not a showstopper, I guess.
Zinc plated clipp
Inside viewing about the sidelamp connection
Gallery mount to the front
------ Follow up post added August 9th, 2014 01:47 PM ------
Have mercy to the following car, use mudflaps
Old August 9th, 2014, 03:56 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Paintwork
Old August 9th, 2014, 04:08 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Assembling
------ Follow up post added August 9th, 2014 02:11 PM ------
Old August 9th, 2014, 04:18 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
First roll out
Well, the draought bar is very short!
Old August 9th, 2014, 04:30 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Heavy duty
Feel free to ask about Sankeys.
I'm done.
Old August 10th, 2014, 11:28 AM
Very nice. So are the chains to stop the mud flaps going forward into the wheel? And did you live with the short draw bar, or make it longer?
Originally Posted by pendy
I'm here for the D's
Old August 10th, 2014, 11:51 AM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Thanks Charles,
yes the chains stop the mud flaps swinging towards the tire.
I will make the draw bar longer. About 1 1/2 ft.
But this is a project for the future.
Old August 18th, 2014, 05:57 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Forgot to mention ...
Please have a look:
After lathing the pots I drilled the remainig holes inside the lathe by using their own gearbox.
To match the diameter for the original fixings try 1 3/4".
13 1/2 revs are necessary at the gearbox for a full 360 turn on the lathe's spindle.
With this deviding item it's an easy job. And a driven tool too.
First hole:
to set the second hole, set the bolt on 1/2 of the disk and turn 4 1/2 turns.
Same precedure for the last one.
I use an old gearbox in an other tool to get the threads ready.
axle, engine
Pile of Sankey trailers atlcruiser The Vendors Loft 136 March 10th, 2015 11:47 AM
Sankey Wide Track trailers globallandrovers For Sale - Vehicles 11 September 1st, 2010 11:01 PM
Sankey Trailers ajh For Sale - Vehicles 5 May 7th, 2010 08:20 AM
Check Enginge light and Gas Cap floyd650 Defender Technical Discussions 13 December 27th, 2007 05:44 AM
Sankey Land Rover trailers. Ex-British Army AUSTINSJEEP For Sale - Vehicles 0 November 28th, 2007 10:05 PM
