Just failed NJ emissions inspection - Defender Source
Old June 25th, 2014, 10:06 AM
ymc226
Lawrence
1995 D90 SW NAS
Took my new to me '95 NAS and failed the low idle part but passed the high idle.
Not being familar with engines, could this be an expensive repair? Using either 91 or 93 octane gas if that makes a difference.
Old June 25th, 2014, 11:12 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
No biggie. How long did you drive the truck for before getting it tested? Also did you take it to a shop or the state inspection?
Old June 25th, 2014, 12:13 PM
ymc226
Lawrence
1995 D90 SW NAS
Drove from Princeton to the State Inspection facility in South Brunswick so about 25 minutes but I got there 40 minutes early to be first in line; the car was shut off for this amount of time before it was restarted and driven right into the inspection bay.
Also, would the prior owner installing a Magnaflow exhaust system affect the outcome?
Old June 25th, 2014, 12:21 PM
airbornrover
William Skidmore
SIII 109 SW
Exhaust pipe has nothing to do with it. Probably the cats were not hot enough. Go to the station again and while you are waiting run the engine at 2000rpms and that should be sufficent to keep your cats hot enough so that it passes emissions. My fathers mechanic that he takes the truck to told me that little trick.
Old June 25th, 2014, 03:27 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
If bet with new o2 sensors you'd pass. That's what happened to mine. Super easy to do yourself too.
inspection
FAILED Maryland Emissions test Flagg Defender Technical Discussions 47 April 22nd, 2015 03:27 PM
Failed Emissions! Defender_90 Defender Technical Discussions 16 May 2nd, 2012 03:32 AM
Emissions – failed Hydrocarbons PPM down_shift Defender Technical Discussions 5 October 20th, 2011 11:00 AM
Tail lights Failed and I got arrested!! RickM Defender Technical Discussions 8 April 21st, 2008 06:02 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
