Just damn, my Defender finally left me stranded - Defender Source
Old May 27th, 2012, 10:53 AM
hartman
Edward Hartman
1997 D-90
It was enevatable after owning 4 different models over the past 17 years, without a hitch.
The specifics;
1997 D90 ST
Milage 71,000
I was traveling 45 mph and lost power. The oil light, battery light and service engine light came on. I coasted into a business and placed the vehicle in P. I double checked the fluids, battery cables and everything checked ok. I attempted to start the 90 and the vehicle turns over and attempts to start, then cuts off.
The check engine light stays on now.
I think the fuel pump is shot. I checked the fuse and it wasn't blown. Yes, I have fuel, I have only gone 135 miles on this tank.
Now I'm waiting for a roll back to take the vehicle to the Land Rover dealer in VA Beach. I just hope they don't have a gate blocking the entrance.
Oh, did I mention my doortops, and soft top windows are 1 hour and 45 mins away from me. + it's starting to rain.
FML
Old May 27th, 2012, 11:02 AM
What does the code on the ECU say?
Old May 27th, 2012, 11:06 AM
hartman
Edward Hartman
1997 D-90
I have no way to check the ECU
Old May 27th, 2012, 02:05 PM
sounds like a fueling problem to me. the big test is do you hear the pump prime when you turn on the ignition? If no, then there you go.
Old May 27th, 2012, 03:13 PM
Yah, that sounds like a fuel pump. Do you have to drop the tank on those to get to the pump?
You probably do not have to replace the entire fuel pump cartridge, just the actual pump part. I just did that on the LeWB. Got a generic pump and filter from NAPA. Took out the cartridge, replaced the pump, had to recombobulate the wires a little, and put it back. Works great and was less than $70.
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Finally a Defender owner again Marinerover Misc. Chit-Chat 3 March 29th, 2011 01:42 PM
2007 Defender details announced Kev Baldwin Misc. Chit-Chat 17 August 22nd, 2006 09:01 PM
Defender in Paris, and Mystery Guest Doug Misc. Chit-Chat 20 June 18th, 2004 01:52 PM
Thinking of buying a '94 ST Defender Mark M Defender Technical Discussions 19 June 7th, 2004 11:20 AM
