Jack Recommendation - Defender Source
Old April 3rd, 2006, 12:28 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jack Recommendation
So what do you guys have in your trucks incase of a flat tire on the road?. I have a small floor jack in a plastic case from Sears but its so damn heavy and large. Any ideas for something small and light weight??? Remember that I have 35" tires so the axles are a bit higher then normal...
Legend in My Own Mind.
Old April 3rd, 2006, 12:49 PM
I have two factory LR Bottle jacks. I also have 35's and they work out fine. I also carry a highlift too.
Old April 3rd, 2006, 01:10 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
A LR bottle jack and a lenght of 4"x4"
3rd low and BOOT IT
Old April 3rd, 2006, 03:08 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I carry a HiLift for ease and speed. I also carry the LR bottle jack which Mike Hippert pointed out needs some work. It will not extend all the way.
If I can find that link I'm gonna fix it.
Old April 3rd, 2006, 03:17 PM
LOL!
I like the land rover bottel jack! But it needs to be stored upright otherwise it will stop working just when you need it! It always worked for me with 35s, no matter what jack you use it may not be big enough at times, but for the most part the LR jack dose what is needed!
Old April 3rd, 2006, 04:33 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have to find me one of those. Thanks guys
Old April 3rd, 2006, 05:02 PM
Hillbilly Raider
MANDY STRINGER
Tombraider90
I carry a brakedown recovery card and a short skirt!
A not quite over the HILLBilly.
Old April 3rd, 2006, 05:11 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Cool
I tried the short skirt but the only place it worked for me was San Francisco.
Old April 3rd, 2006, 06:52 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
"This thread is worthless without pictures."
DW
Old April 3rd, 2006, 07:13 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
The OEM Jack is pricey. Try Griots. They had a nice one. I believe any tractor supply store will have a bottle jack as well....
ewS
Old April 3rd, 2006, 07:58 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
DW
What hillbillies or tdi's pics
3rd low and BOOT IT
Old April 3rd, 2006, 08:39 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
lol... skirt pics...
Old April 3rd, 2006, 08:44 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Carry a ratchet strap and a high lift. Strap the axle up and lift on the slider. No need to carry an extra jack.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 3rd, 2006, 09:36 PM
scoloco's Avatar
scoloco
'94 D90 ST
A decent bottle jack and a hunk of wood should work. The bottle jack should be small and fit almost anywhere. Hilift is big and a pita to get out to use. Ditto with the ratchet strap...
Old April 3rd, 2006, 10:00 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I agree, I carry a Hi Lift but 9/10 times a bottle jack and a a few 4x4 pieces work great and fast for changing a tire on the trail. Various sizes of wood should be a part of every wheelers recovery kit.
Old April 3rd, 2006, 11:36 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
bottle jack and Hi-lift base for changing a flat. You can also use the bottle jack on the trail if you get hung up on your diff. Put the bottle jack under the diff lift it high enough for clearance and drive off of it. Better and safer than a hi-lift. Yes I do carry a hi-lift too.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old April 5th, 2006, 12:43 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Same here, hi-lift and I keep the bottle jack in there as well.
If you want a new bottle jack, you can snag them off e-bay sometimes. Or get a different brand one from some place like northern hydraulic or harbor freight tools.
-Hans
My oil line fix
My 100k stopped odometer fix
ac
Bottle Jack Maintenance? Eric Siepmann Defender Technical Discussions 8 July 15th, 2007 12:04 AM
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
Hi-Lift Jack easy Wanted 6 May 13th, 2005 12:14 PM
jack alternatives artm Defender Technical Discussions 7 February 27th, 2005 01:59 PM
Mounting hi lift jack to Brush guard Cyborg Defender Technical Discussions 12 May 3rd, 2004 10:09 AM
