jack point on sliders - inner diameter? - Defender Source
Old June 8th, 2008, 07:19 PM
Guys, can someone with rock sliders that have the integrated hi-lift jack mount point built in (basically a piece of tubing) tell me what the inner diameter of that tube is? I assume its for a hi-lift attachment, as I don't have one.
thanks
charles
Old June 8th, 2008, 07:51 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
This is on Mantec sliders
ID:	13790   Click image for larger version
Old June 8th, 2008, 10:03 PM
Thanks Chris!
Old June 9th, 2008, 09:36 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Should be the same as is on your rear crossmember or front frame horns.
Old June 9th, 2008, 09:42 AM
cellulararrest
Chris Snyder
True. The adapter fits in the front frame horns. Never tried the rear crossmember.
Old June 9th, 2008, 09:51 AM
Good point, thanks.
Old June 9th, 2008, 11:32 AM
The holes are for the stock jacks........
Old June 9th, 2008, 12:49 PM
cellulararrest
Chris Snyder
? Why would you jack the frame with a stock bottle jack? You'd never get the wheel off the ground. I doubt the stock jack would even reach either the front or back holes.
Old June 9th, 2008, 12:51 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Non-nas trucks had this bizarre jack that was somewhat hi-lift-ish but far less safe (if you can imagine). They have a receptecle that fits into those holes.
Old June 9th, 2008, 12:54 PM
cellulararrest
Chris Snyder
Ah gotcha. That makes more sense
Old June 9th, 2008, 01:07 PM
Janey has one of those jacks in the back compartment on the right hand side.
Old June 9th, 2008, 01:43 PM
Abrooks's Avatar
Abrooks
Tony Brooks
There's one in the back of my truck -- I hooked it up once and was scared senseless of actually using it.
Old June 9th, 2008, 02:05 PM
Yeah haven't tried mine, although I do carry it around.
charles
Old June 9th, 2008, 02:17 PM
http://i14.ebayimg.com/03/i/000/e6/8e/28af_1.JPG
ac, slide
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
jack alternatives artm Defender Technical Discussions 7 February 27th, 2005 01:59 PM
Best Rock Sliders for a D-90? Seriesman Defender Technical Discussions 9 July 16th, 2004 11:41 AM
Mounting hi lift jack to Brush guard Cyborg Defender Technical Discussions 12 May 3rd, 2004 10:09 AM
