Issues with 200TDI engine in cold? - Defender Source
Old August 5th, 2016, 03:26 PM
kracdown
Elliot
1991 D110 200Tdi
I'm about to pull the trigger on a 1991 110 200TDI... But the car will be with me through the tough Chicago winter. How does the engine take the extreme cold? I know the thing will otherwise be a beast in the snow.
Old August 5th, 2016, 03:51 PM
burlsube
Nick
1985 110 CSW
I have a 110 with a 200tdi and I am located in Boston. My only observation is that in the extreme cold, there will be very little heat produced by the engine. The drivers and passengers may get a little heat, but anything behind the first row won't. I'm looking to add an auxiliary heater for the back this year.
Old August 5th, 2016, 03:59 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
https://youtu.be/IgyIJWaTvEw
Boston a few winters ago. give it plenty of glow and it fires right up.
edit: forgot to add, at 45+mph expect all heat to be sucked out and the cab become an ice box. Aux heater is the way to go if you expect to drive long distances in the cold. I've never had an issue with congealing diesel except in my vw tdi which is fussy with its fuel.
Old August 5th, 2016, 04:12 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
The 200TDI will usually fire right up in the severe cold.
If it doesn't, we offer heavy duty controllers and new glow plugs that will make a difference and have it starting like it should.
Consider a webasto airtop diesel fired heater that will supply all the heat you need.
If you go with the remote control, you can start the heater before you get inside and then drive around in frigid temperatures in shorts. sandals and a tank top.
RDavisinVA
Old August 5th, 2016, 05:02 PM
Naplm00
Matthew
Glow plugs, engine block heater and oil pan heater are your friends in the cold. With mine all hooked up fires up like it's 80 degrees outside.
For better internal heat I juts block the rad with a wooden board so the engine can get to temp
Old August 5th, 2016, 06:47 PM
burlsube
Nick
1985 110 CSW
edited out
Old August 5th, 2016, 09:51 PM
Cajun
G
1987 110
If you want to see some diesels in Chicago, there will be a few at the next Chicago Land Rover Club Mtg on Wed Aug 17th in Villa Park
Old August 6th, 2016, 08:03 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
X2 on the Rad Muff. You might also convert to electric rad fan and only turn it on when engine temps justify.
tdi, 200tdi, engine
Starting issues warm engine 200tdi Mes788 Defender Technical Discussions 13 November 30th, 2015 10:52 PM
1985 2.5 n/a cold start issues suburbanloki Defender Technical Discussions 6 October 22nd, 2015 11:53 AM
D110 Cold weather diesel issues 300tdi Borismill Defender Technical Discussions 17 March 7th, 2015 08:00 AM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Cold engine idle surges Bozman Defender Technical Discussions 4 May 22nd, 2007 09:21 AM
