iPhone and iPad mounts - Page 2 - Defender Source
Old January 7th, 2013, 10:46 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Search for NomaD110 and check out his posts in the iPhone mount thread. (Sorry don't know how to link to that on my phone) he has a very slick set up. I've seen it in person, it's nice and very rugged.
Old January 7th, 2013, 01:55 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Get the Touratech Iphone mount and a Ram connector (get the short arm). Then all you need to do is mount a Ram Ball to a spot in the cabin. Then you can remove the entire mount if you want it out of the way and it will adjust to any direction you want. Ipad would mount to the same ball with a different cradle. Then order up a 3.5MM male to male cord with an inline microphone and run it from the aux port on the stereo to the Iphone cradle. Boom, you have the equivalent of bluetooth in the car for 3 bucks and you can use SIRI, get text messages and turn by turn directions over the car's speakers. I have this setup in my pickup, works great. I smile whenever i see people trying to retrofit aftermarket bluetooth systems into their cars for hundreds of dollars.
Here is the link to the Touratech mount. I run it on my Dual Sport. It's didn't move around on that and there is nothing you can do off road in a Defender that will be worse than 80 mph through Baja..
http://www.touratech-usa.com/Store/P...acket-iBracket
Old January 7th, 2013, 02:46 PM
winn442's Avatar
winn442
Winn Bearden
Here's my setup, I looked a about a thousand mounts on line, I wanted a mount where I could just drop it on without having to plug it in ....... Mounted with emblem tape, drilled a hole for the cable where the LR oval emblem goes so I can cover the hole later if needed. Interfaces with the Pioneer nav unit.
Works fine commuting, when I go offroad I have a rubber band to put on it to hold it in place.
Hopefully one day there will be a interface where one can have full iphone control through the head unit wirelessly....
Went from a Otter to Ballistic last week and had to remove some plastic from around the connector for it to plug in fully.
Name:	iphone mount.jpg
Winn Bearden
Old January 7th, 2013, 02:49 PM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
i used the RAM no drill universal mount that bolts to one of the seat bolts. that with the Ram ipad mount hold my ipad with griffin survivor case perfectly. the only change i made was attach the uni mounting post to my center console with a little piece of kydex. now the post is mounted to the seatbox with the bolt and 8 inches up.. to the console. rock steady.
also because i used the passenger seat bolt, the ipad sits in the perfect spot for my arm to rest on the NAS center console, while using it.
pic: best pic i have on my iphone ... if you would like i can take a few tomorrow.
also here a pic of the iphone mount i am buying... my wheeling buddy has it and it is sturdy. also it fits all phones with all cases.
TIP: only purchase the version with the all aluminum mounting ball. the plastic/ composite version have not held up offroad.
Hope it helps.
ID:	64012   Click image for larger version
ID:	64024   Click image for larger version
Old January 7th, 2013, 07:18 PM
bossman429's Avatar
bossman429
Adrian
1988 90
All great stuff guys. Thanks! I'm going to get the pro clip for the phone and see if I can figure out the iPad after that comes in. Being I have a row truck i have a few less places it can mount too
Old January 7th, 2013, 07:36 PM
Rover110
Steve
1993 Defender 110 NAS #472
RAM Mount Twist Lock Suction Cup Base w/Universal X-Grip II
http://goo.gl/MW0Lf
Old January 7th, 2013, 07:42 PM
Lemonhead
TB
1997 D90 SW
As mentioned - I have the PrpClip with an iPhone. Not sure I would put an iPad on it though as it may be too much in your face/blocking the windshield (unless it's a mini). Though I haven't looked at the ProClip iPad mount - maybe it's adjustable - don't know.
Old January 7th, 2013, 09:18 PM
Korongo's Avatar
Korongo
Cameron Bell
1984 Defender 90, 1988 Defender 110
Ram Mount
Anyone use the ram mount cup holder? I'm thinking about using their suction cup on my windshield.
Old January 8th, 2013, 10:27 AM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
The ram suction cup mount is the strongest of the type I have ever used.
Before I purchased the hard mount I used the s cup for my iPad....and it held fine offroad in the rocks. I'm positive it will hold a cup holder well. The only problem I foresee is extended exposure to heat and UV will eventually degrade the elasticity of the suction cup. I always removed mine...but here it's really hot.
Good luck.
EDIT: my previous post ...I have a ROW console.
Old January 8th, 2013, 03:38 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Took me a while to respond but here are some shots of my mount. Obviously this is a ROW dash.
The spring loaded mount fits all of the iPads, even if they are in a case.
ID:	64113   Click image for larger version
ID:	64115   Click image for larger version
Old January 8th, 2013, 03:48 PM
Your rig is an auto trans?
Old January 8th, 2013, 03:51 PM
navydevildoc
Neill Thornton
Yup....it's awesome.
Old January 20th, 2013, 07:13 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Originally Posted by Reese_D90 View Post
This may not handle the bouncing off road but I like how clean it is for the iphone. I just ordered this and I am planning on mounting it at the bottom of the ashtray and feeding the connection back thru the dash to the radio. When the ashtray lid is open, just plug it in.
http://stores.homestead.com/2point5/...V2I/Detail.bok
Installed the Iphone mount this weekend. The ashtray location worked out well.
Name:	2013-01-19 11.48.19.jpg
ID:	64810   Click image for larger version
Name:	2013-01-19 11.49.48.jpg
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old January 20th, 2013, 08:32 AM
Can you please tell me this thing was not $150?
Old January 20th, 2013, 08:39 AM
Reese_D90's Avatar
Reese_D90
Reese
I looked everywhere for a better price. No other option that I could find
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old January 20th, 2013, 11:09 PM
RobTheGob's Avatar
RobTheGob
Rob
1963 IIa 88 & 1995 NAS D-90 SW
Wow. I think I'd be able to mod an Apple dock ($30) to work. You could likely buy the dock and a Dremel tool for less than $150.
Maybe I'm missing something - is there something special about the $150 dock?
Old January 24th, 2013, 05:55 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
This thread made me realize that I don't need a new and expensive, touch-screen radio and dash mount when I can just use my iPad with 4G. It's perfect and way more advanced than any touch screen radio.
So I ordered the Ram mount for iPad ($22 from Amazon), should have it tomorrow. I also just installed an aux-in adapter ($10) for playing audio from the iPad through the stereo system and wired it up to my dash storage shelf. I also hardwired a cigarette lighter adapter behind the dash for constant charging power for the iPad. No messy wires will be visible and my other CLA will still be available for other uses.
Now I need to decide where to mount it. I would like to mount the attached cell phone mount in the dash storage area to the left of the clock/hazard lights/CLA cluster. And I want the iPad to sit just above the clock/hazard lights/CLA cluster.
My question is, what is underneath that storage shelf? I have AC so I know that's in front but below the dash but what is behind the AC system in the shelf area? Any major wiring that I could drill into? I want to drill straight down into the shelf. Thoughts?
ID:	65096   Click image for larger version
Old January 24th, 2013, 07:11 PM
Shawn's Avatar
Shawn
shawn Orth
1994 Defender 90
I ordered a ram a couple of weeks ago and still have not seen it. Please let me know if you get it tomorrow.
Old January 25th, 2013, 11:00 AM
bossman429's Avatar
bossman429
Adrian
1988 90
My pro-clip finally came in. Very simple and clean product. Stays in place without the adhesive, but I used it anyway. Mounted as such so if I want to get the iPad mount i will fit without hitting the gauge cluster and covering only a portion of the radio controls.
Very sturdy, I like.
ID:	65108   Click image for larger version
Old January 25th, 2013, 11:02 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Yea.. I'm gonna agree
ipad, mount
Is your dash cluttered?...Stereo & Navigation Solutions Chris Vitale Misc. Chit-Chat 32 August 29th, 2012 08:16 AM
FREE D-90 Source Apps - iPhone + Android Andy R Community News & Announcements 0 May 21st, 2012 04:27 PM
iPad 2 Mount Project continued in D-110 NomaD110 Smaller Projects 2 September 16th, 2011 09:58 PM
