Intervention Needed - Page 3 - Defender Source
Old May 25th, 2010, 04:27 PM
PM sent.
Old May 25th, 2010, 06:11 PM
As far as the overflow for the coolant over flow. I pulled my truck into the shop temp gauge was sitting normal, the laser gauge said it was 212, now at 180 with a real temp gauge verified with the lazer. Stock gauge sits in the same place it did when it wasn't overheating. Rover temp gauges dont work.
Old May 28th, 2010, 01:34 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks Phil, your post got me to flush the radiator yesterday. Got new coolant in and a turkey temp gauge stuck in the radiator. Drive to work this am (15 miles) and the temp gauge reads 160 after parking for a few minutes.
MUDSUX
Old May 28th, 2010, 04:32 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Found an ECU,
part number: PRC 6999 / 84913 A
Will this work on an 88? Can't tell if it's 13cu or 14 CUX
MUDSUX
Old May 28th, 2010, 11:24 PM
That think that will work. It is a 1989 so it is a 3.9, but I don't believe they had the code reader until 1990+.
Old May 28th, 2010, 11:55 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks for the info Ron. Will give it a go and see what happens.
Checked the temp on the way home and it sat at 140. I guess that is good. Don't think I need your new radiator. Not yet anyway. And I don't see any other signs of a head gasket problem. Time will tell.
MUDSUX
Old May 29th, 2010, 04:03 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Ok, so what is this rubber-like wheel thing sticking out the back of my front diff next to the steering damper? Is it to protect the steering rods against rocks? Can't find a reference to it in the manual.
MUDSUX
Old May 29th, 2010, 04:50 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I think it is the harmonic dampener. Not really sure what it does. Mine fell off a long time ago
Spare Tire needed Andrew Vick Wanted 0 March 15th, 2006 01:57 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
1994 D-90 Factory Bestop parts needed?? Adam Armendariz Defender Technical Discussions 2 March 30th, 2005 08:25 PM
manual transmission needed ember Wanted 0 August 31st, 2004 11:50 PM
What Parts Are Needed For A P/U Cab? javelinadave Defender Technical Discussions 6 October 25th, 2003 09:48 AM
