Intercooler comparisons - Defender Source
Old November 4th, 2008, 06:44 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Here are some pictures of different intercooler upgrades I have worked with. Shows differences and some of the things that need to be overcome to make an upgrade happen.
The larger intercooler I have Allisport make is in the background. And the stage II Allisport can be shown next to the Australian one you guys have been buying on EBAY. The AUS one has thicker cores that are blocky and hassle airflow in my opinion. And the airflow gap is smaller as well. the AUS and Allisport stage II are the same size and not true full width intercooler IMO.
You can see the large section left with the smaller intercoolers around the intercooler intake and exit pipes. That has to be closed off to keep airflow from recirculating in the engine bay. The Shroud needs to be closed off as shown to keep air moving across the radiator.
I also show a larger radiator I make that butts up to the intercooler pipes and allows more cooling. And another picture of the external oil cooler I like to replace the restrictive oil cooler that is usually in a tank of the stock radiator.
Jim Pendleton
ID:	16159   Click image for larger version
ID:	16161   Click image for larger version
ID:	16163   Click image for larger version
ID:	16165   Click image for larger version
legend in my own mind
Old November 4th, 2008, 10:16 PM
Thanks for posting the pictures Jim. Makes what you were telling me over the phone much clearer than the mud I was dealing with. Is that a ball of sheep wool in the background ?
Old November 5th, 2008, 12:02 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Steel wool. Has the same effect over me though.
Old November 6th, 2008, 08:06 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Out of curiosity ...
What do you guys do with the crossbars that go in front of the radiator from the hood catch to the chassi when installing a big intercooler ?
Pat
Kirk Lazarus, Tropic Thunder
Old November 6th, 2008, 08:17 AM
I already removed mine. I was reading Allisport and others websites and they all say you have to remove them.
Old November 6th, 2008, 08:21 AM
Retrofit's Avatar
Retrofit
Pat
And off they come ! (save some weight )
Thanks !
Pat
Old November 6th, 2008, 10:56 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I don't remove them! I move stuff around to make it fit with them. Hoods don't shut as well without those pieces installed. Or a replacement that curves out and covers the new addition. Some of the installation tricks I am going to keep to myself.
JP
Old November 6th, 2008, 02:12 PM
JP,
Question. In your pictures you show how the Au intercooler isn't full width. Does it make sense to move it as far to the left as possible and free up some air flow to the radiator ? Pointless ?
Old November 6th, 2008, 04:02 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Then you put the tank for the intercooler in front of the radiator. Blocking flow. Its a compromise however you end up mounting it.
Correct intercooler for International 2.8 engine Santiago Defender Technical Discussions 5 June 13th, 2008 04:12 PM
Allisport Intercooler Santiago Defender Technical Discussions 5 June 10th, 2008 11:16 AM
Intercooler D90user Wanted 3 November 26th, 2006 02:59 AM
Intercooler cleaning D90user Defender Technical Discussions 8 September 29th, 2006 09:35 PM
Tdi intercooler tube diameter artm Defender Technical Discussions 1 December 30th, 2005 12:13 PM
