Installing Hella 4000 Raylle driving lights - Defender Source
Old June 9th, 2014, 09:50 AM
ymc226
Lawrence
1995 D90 SW NAS
A cheap upgrade to the Hella 3000 lights that are mounted on my ARB bumper is the 4000 Eurobeam from Amazon for $108 each.
I am getting the ARB headlight harness installed this week and asked the service to hook up the pre-existing 3000 wiring to the upgraded harness. I don't want to take it back just for another install and would like to do the work myself.
Along with the recommended harness http://www.amazon.com/HELLA-14854100...gy_auto_text_y, what other parts and tools are required to make the connections as water resistant as possible? I've read of wrapping the connections in shrink wrap. Can these be found at Home Depot.
Also, the harness comes with a switch from the picture but my present lights are already connected to a switch at the base of the steering column. Can I not use the switch on the harness?
------ Follow up post added June 9th, 2014 09:59 AM ------
I plan on changing the older 3000 harness as it is quite old and plan on just following the route of the older harness with the new 4000 harness to the ARB loom if that makes sense.
Old June 9th, 2014, 10:16 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Your previous thread:
http://www.defendersource.com/forum/...eferrerid=7536
Diagram (simplified):
http://www.fuddymuckers.co.uk/galler...ght_wiring.png
How to waterproof a connection:
Yes the heat shrink tubing and torch ect can be gotten at home depot.
Old June 9th, 2014, 03:34 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks Jason.
Old June 9th, 2014, 07:04 PM
Lemonhead
TB
1997 D90 SW
BTW
The relay set up included with Hella harness is not waterproof - it will rust and go bad rather quickly if it gets wet.
You may want to upgrade to a waterproof relay kit similar to below.
ht, lights, vin
FS: Hella 4000 Lights fleabus For Sale - Parts 1 May 8th, 2010 09:45 PM
2 Hella 4000 (Euro Beam) plus Hella wiring harness Gore Ranger For Sale - Parts 9 January 2nd, 2010 08:26 PM
Hella 4000 Driving Lights/Spare Distributor Wires/Work Light AJKing Wanted 0 October 4th, 2008 11:28 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
Hella 4000 lights! TwisteD90 For Sale - Parts 17 October 7th, 2003 04:32 PM
