Independent LR shop near Fredericksburg, VA - Defender Source
Old March 20th, 2013, 03:13 PM
110Landy
Paul
1984 110 2.5D
Does anybody know of a good LR shop near Fredericksburg or Ft. Belvoir, VA? Unfortunately my '95 RR is not so simple as the diesel 110. I just need somebody to hook up the computer and print out the stored codes and then clear them. Pikes Peak Rovers in Colorado Springs used to do it for me for about $25 and it took no more than 15 minutes. The places I have called here want $100 and tell me that I have to leave the truck so a technician can do a full diagnostic scan, blah, blah, blah. Sounds like they are trying to make money. I am not driving a fancy new RR to pick up groceries. I have a 17 year old RR that pulls logs, hauls feed, tows any manner of trailer, gets used as a bulldozer, etc. I need a LR shop that understands what a LR is meant to do.
Okay...enough of my soapbox rant. Any help?
Thanks.
Paul
Old March 20th, 2013, 04:58 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I think the closest will be Roverland in Alexandria.
Old March 20th, 2013, 06:40 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Avoid Roverland, they are clueless. Isn't it OBDII? You are welcome to swing by Quantico and we can scan your codes.
Semper Fi!
Old March 21st, 2013, 01:21 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
If it's OBD-II, then take Jonathan up for it or stop by Advance Auto Parts and they'll pull the codes for free.
If OBD-I, you should be able to cycle through the display unit, right?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old March 21st, 2013, 04:17 AM
Lemonhead
TB
1997 D90 SW
Or just get a scanner - pretty cheap these days.
http://www.amazon.com/s/ref=nb_sb_ss...%3Aodb+scanner
Or if you wanna go fancier.
http://www.automatic.com/
Hope that helps.
Old March 21st, 2013, 07:53 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Possibility in Montpelier VA...
Originally Posted by 110Landy View Post
Does anybody know of a good LR shop near Fredericksburg or Ft. Belvoir, VA? Unfortunately my '95 RR is not so simple as the diesel 110. I just need somebody to hook up the computer and print out the stored codes and then clear them...
Paul
I know a guy in Montpelier VA near Ashland that may be able to help, I'll ask and send you a PM. It's a little further away, but not a long drive.
To clarify you want a report on and clearing of the ECU engine codes on a 1995 NAS Range Rover. Is that correct? Please advise.
RDavisinVA
Old March 21st, 2013, 09:24 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
It's not OBD 2.
What does the underseat display show as a 2 digit code?
Email is
Same place, new dogs.
Old March 21st, 2013, 09:31 AM
Viggen's Avatar
Viggen
Jarrod
none
I never had a problem with Roverland.
Old March 21st, 2013, 01:37 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Roverland is run by a bunch of idiots
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old March 21st, 2013, 01:47 PM
Wolf Fabrication
Sterling Archer
'08 D3
Thank you. I couldn't agree more.
I've called them several times and they were baffeled on the most simple questions. One time some kid answered the phone and pretended to know Rovers, like the Land Rover 110 was only made in 1993 and said I must be confused on what truck I have.
One time I was told you can't re-gear land rover differentials - you have to buy complete 3rds.
Another time I called in desperate need of some Salisbury differential shims and was told LR never had a Salisbury axle.
There was a third time I called and was so baffled, but it's slipped my mind.
Semper Fi!
Old March 21st, 2013, 01:58 PM
It should be odb1 and you can either see and clear the codes using the display and connecting/disconnecting the ECU, or if you have a laptop you could use roverguage with about $20 worth of parts to make a cable. Come to happy hour in Springfield tonight and I'll show you the codes and clear them for you.
Originally Posted by pendy
I'm here for the D's
Old March 21st, 2013, 02:11 PM
The Dro
Dro
1988 Ninety
You just like calling them... I went there once and that was it for me.
Old March 21st, 2013, 02:51 PM
Holiday's Avatar
Holiday
Ross Simpson
1995 D90 ST/2006 D3 HSE7
Agreed. Stay away from those clowns. I had my truck there three years ago to do a laundry list of servicing, and my impression of them got so bad, that I paid them to put it back together and drove off. Incompetent troubleshooting, poor communication, and expensive. Perfect for 80% of the NoVA drivers with blinged out Ranges, but a dissatisfying experience for anyone who knows better...
Old March 21st, 2013, 03:01 PM
carlosz's Avatar
carlosz
Carlos
if you feel mechanically inclined or just curius.... http://www.robisonservice.com/servic...er_trouble.asp
need good LR mechanic in Herndon, Va. slorocco Misc. Chit-Chat 6 June 24th, 2012 03:01 PM
Great LR Service Shop In Washington DC Metro Area (Gaithersburg, MD) dmb Defender Technical Discussions 3 June 11th, 2012 09:43 PM
Arlington, VA shop question smob Misc. Chit-Chat 22 September 10th, 2008 07:22 PM
Portland Oregon LR Repair Shop kmg99 Defender Technical Discussions 3 May 17th, 2005 12:18 AM
New Independent Rover shop in Denver avali Defender Technical Discussions 0 March 31st, 2005 05:14 PM
