Impressive build quality - Page 2 - Defender Source
Old October 4th, 2015, 10:41 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
There are a few things that I would do differently but holy shit this is a clean and well done build! I hope you get a ton of money for it!
Old October 4th, 2015, 12:05 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
Hit your tunnel with a DA sander, lay down some high build primer, and keep sanding until it's smooth. FG is much easier to get quick results from than most materials. I was lucky and the original tunnel was in excellent shape but it still required some love to make it look perfect. I shot the underside of it with the color matched bedliner to eliminate the ugly natural fiberglass look.
Regarding the electronics, are you referring to an MFU (Multi Function Unit)? Is your Defender a 97?
Originally Posted by jason1st View Post
I love it. My build is nearing completion. One of my sticking points is the R380 trans tunnel made of fiberglass. I hate the finish on it. Your looks so much better. Did you do something to it?
Also, where is the box that manages the electronics?
------ Follow up post added October 4th, 2015 09:09 AM ------
Thanks for the props!
Old October 4th, 2015, 12:52 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yeah, great work. Hope that price on eBay goes way up with the work you've done. Very thorough build up. Kudos.
Old October 4th, 2015, 12:55 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Why? The tunnel cover should be covered with a rubber mat for sound and heat reduction.
Old October 4th, 2015, 01:17 PM
bjf's Avatar
bjf
barry f
94 ST #395
Is there a cover over the rear crossmember?
Old October 4th, 2015, 02:11 PM
cwilder's Avatar
cwilder
Chad
2012 110 Black
Do you have a soft top for it? Sweet build, I really like this 90!
_________________________________
2016 Range Rover TD6
2013 Raptor F150 SVT
1997 D-90 #1867 (sold) :(
2012 Black 110 :) In OZ still
2011 LR4 "Metropolis" (sold) :(
2011 Raptor F150 SVT (sold) :(
2007 Shelby GT500 (sold)
2007 LR3 (sold)
2006 RRS (sold)
Old October 4th, 2015, 02:56 PM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
Yes. The MFU. Mine is a 1984 110 with a new 4.6 Gems and R380. We have the MFU in the engine bay. I don't like it unless that's the right place for it.
------ Follow up post added October 4th, 2015 02:56 PM ------
Why? Because this one looks kick ass. I don't like the rubber mat look.
Old October 4th, 2015, 03:16 PM
CLMorgan
C.L. Morgan
Well done restoration thats makes my OCD all warm and fuzzy
Not a fan of the rims and color but imagine thats what is getting top dollar these days.
Old October 4th, 2015, 03:37 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yes. The MFU. Mine is a 1984 110 with a new 4.6 Gems and R380. We have the MFU in the engine bay. I don't like it unless that's the right place for it. ------ Follow up post added October 4th, 2015 02:56 PM ------ Why? Because this one looks kick ass. I don't like the rubber mat look.
Without the rubber it all gets hot as shit
Old October 4th, 2015, 03:48 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
Just the bikini. I have used the Badger half-cabs tops before and really like them but the wait time to get it pushed out well past when the Defender would be sold.
------ Follow up post added October 4th, 2015 12:55 PM ------
I drove it in 110 degrees to test the fan set up. I let the truck achieve full temp first. No noticeable heat or additional noise from the tunnel cover. The seat box, bulkhead, doors, and hood are not insulated from the factory. Not applying the rubber mats makes a negligible difference in sound and heat. I doubt that anyone will be driving this in hotter temps than I have here in Scottsdale. I put a couple thousand miles on my D110 soft top pickup with the same results.
------ Follow up post added October 4th, 2015 12:57 PM ------
Different harness than mine. I didn't have a big ungainly MFU to hide.
[QUOTE=jason1st;677016]Yes. The MFU. Mine is a 1984 110 with a new 4.6 Gems and R380. We have the MFU in the engine bay. I don't like it unless that's the right place for it.
Old October 4th, 2015, 04:02 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
I welded a 3/16's steel plate over it to provide reinforcement to the drop down tailgate hinges (converted back to swing away) and integrate the body mounting tabs. I didn't like the extra errant holes in the back of the NAS crossmember. I also rolled 3/16's over the top and sides of the crossmember to eliminate the apertures on the crossmember sides that collect dirt and water.
The modification was both aesthetic and structural. I did the same with my 110.
Old October 4th, 2015, 05:25 PM
jason1st
Jason Crandall
Does that rubber mat alone help a lot?
Old October 4th, 2015, 05:55 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
It does make a difference, but removing it does not make the truck unbearable IMHO. Blocking the natural airway with a winch bumper and skid plate cause more heat build up in the tranny/exhaust area than removing the mat. I have tested this with a IR gun on a couple of different trucks after noticing high temps in the console and tunnel area.
Old October 4th, 2015, 11:53 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Yes - road noise is transmitted through the single wall floorboard and lower bulkhead, adding dampening and insulative layer to these areas reduces the transmission of sound into the cabin from below.
Heat transfer from some engines to the floorboard can be felt as radiant heat - again insulation helps to comfort the driver/passenger.
Old October 5th, 2015, 08:18 AM
jason1st
Jason Crandall
I drove the truck about 5000 miles before we started working on it and yes it gets hot.
However, with all the threads about dynamat and bedliner solutions I never thought just a rubber floor mat would do the trick.
Old October 5th, 2015, 08:26 AM
I drove the truck about 5000 miles before we started working on it and yes it gets hot. However, with all the threads about dynamat and bedliner solutions I never thought just a rubber floor mat would do the trick.
How about dynamat plus the Wright rubber mat thingy?
Old October 5th, 2015, 08:40 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
This is why tuffy boxes are (or should be) mounted on strips of wood. To prevent the metal to metal heat transfer. Thinking you could cook eggs on an uninsulated metal tunnel box. Those V-8 CATs are ~ 400 F and less than an 1-inch away.
Old October 5th, 2015, 10:35 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I always feel heat coming right up through that area above the cats.... nice in the winter... Summer it is so hot anyways that I barely notice...
Old October 5th, 2015, 10:42 AM
asif k.
KAHN ALLOY WHEEL 18" X 8" RETRO STYLE - Rovers North - Classic Land Rover Parts
This might have been a better wheel choice, still 'Kahn' design, has the blingy look you probably want but less offensive.
Old October 5th, 2015, 09:28 PM
cwilder's Avatar
cwilder
Chad
2012 110 Black
You can always sell the wheels if buyer doesn't like and put Boost's
2007 LR3 (sold)
2006 RRS (sold)
WTB Quality used winch 5-6-7,000 lbs MJager Wanted 0 April 4th, 2009 11:12 PM
Quality 110 Pix Please JimC Defender Technical Discussions 2 April 7th, 2008 01:06 PM
High Quality extended bump stops Roadsiderob Defender Technical Discussions 3 August 28th, 2006 03:19 PM
Quality repair in DC area? obrienjb Defender Technical Discussions 2 June 28th, 2005 03:17 PM
Looking for a quality used Engines... h2eater Defender Technical Discussions 6 August 8th, 2004 12:27 PM
