Importing 1990 D90 from Greece with replacement of same motor ok? - Defender Source
Old September 23rd, 2015, 07:07 AM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Cool Importing 1990 D90 from Greece with replacement of same motor ok?
Hello,
I have imported a few 97-2000 Defenders to Canada, no problems.
I am looking at a 1990 Defender 90 in Greece (am here now). The stock 3.9L V8 and manual transmission was replaced with the same spec 3.9L V8 motor and transmission.
Is this ok to import into USA New York or will the serial number not match and it will be rejected?
Much appreciated.
Old September 23rd, 2015, 09:18 AM
Something sticks out at me immediately.
I don't think the 3.9 V8 was seen in the Defender until the NAS version. I'm pretty sure it was 3.5 until the NAS versions arrived. So 1990 is way to early for a 3.9 so yours is not powered by the correct unit.
Can anyone confirm or correct me on this?
Old September 23rd, 2015, 09:53 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Early 1992 the 3.9 was fitted to the Defender in the UK, not sure about ROW
I know this as I bought (or the company did) a new 110 Defender on a K reg and it had the new (old) lump in it.
You need do some research on that one. Maybe the plenum has a Crack in it and needs changing
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 23rd, 2015, 11:34 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Decode the vin number, it will tell you what it was from the factory.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old September 23rd, 2015, 12:00 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Verify the VIN configuration - replacement engine of the same type are not grounds for denial of entry as the engine SN is not required for import. Conversion or reconfiguration to a different engine type (volume or fuel type) is grounds for denial of entry.
Old September 23rd, 2015, 05:20 PM
WestCoastRover
Jeff
2000 TD5
Excellent. I will let you know what the VIN reads. It seems A lot of these early defenders in Greece (and only Greece...) have the V8 5.9 from stock.
So on the note of reconfiguration, a 1989 Defender 90 with the 2.5l Turbo Diesel, then replaced with a 300TDi would be denied? (Have my eyes on one in Italy)
Old September 23rd, 2015, 05:27 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Into the USA - yes. Vehicle is not an antique/vintage any longer as it has been modified significantly. Into BC is a whole other story.
You can email me directly as we have some experience importing to Canada as well as the US.
Brian@defendersnw.com
Old November 12th, 2015, 01:51 PM
sakis
sakis
defender 110 v8, range rover 95
all the defefender in greece at tha era are 3.5v8 or 2.5diesel....but is very common to swamp 3.9 efi engines from discos
Old November 13th, 2015, 10:25 AM
WestCoastRover
Jeff
2000 TD5
We bought a MINT 1989 110 in Greece, original owner only 74,000km. It has the v8. The other one we wanted had the 3.9L V8 swap up from 3.5l... I was worried they would figure out and decline it , would they?
Old November 13th, 2015, 10:30 AM
If the block was changed to a 3.9 I doubt it would be a problem. As far as I know they look the same on the outside. What would be a problem is if you went from a carbureted 3.5 to a 3.9. I would consult with your broker to be sure, but that is my guess. I know I can't tell the difference between a 4.0 and a 4.6 without looking at the crank. I assume the same would go for a 3.5/3.9/4.2.
90, ac, d90, import, motor
1990 110 5 door 200Tdi - First Registration December 1990 aaaja For Sale - Vehicles 7 October 19th, 2016 03:32 PM
Need good CV for 1995 lwb should be the same as disco I or 97 d90 evilfij Wanted 6 July 30th, 2013 01:24 PM
Is a NAS 110 Y-pipe the same as a 1995 D90 NAS Y-pipe evilfij Defender Technical Discussions 5 February 12th, 2009 06:10 PM
1990 Isuzu Trooper "Betsy" needs new motor hydrik Wanted 0 December 16th, 2008 12:43 PM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
