Ideas for CVC's "banana flambe" rebuild - Defender Source
Old August 29th, 2005, 08:25 PM
I thought we should start a thread to help Chris Von C. plan the rebuild of his D90.
I see two basic options for Chris to consider:
1. Rebuild as rover V8
2. Repower to Tdi
1. is attractive as it probably can be done inexpensively if compromises are made. Finding a 94 harness will be tough. The dash parts and plastic bits are common enough but sorting the wiring would be a serious nightmare. One option would be to refit a range rover classic engine harness. The block/trans/rad/etc should all be ok. The sensors and such are probably toast but are common to RRCs and DI so used cheap is easy.
2. is attractive because it is Tdi. No wires (well one wire). Spendy though. Have to weld mounts on the frame.
How to start:
1. If it were me I would take lots and lots of pictures for reference. Next I would ask for lots and lots of pictures of 94s to use as a reference as well.
2. Compile a list of needed parts and questionable parts
3. Start removing and cleaning the salvagable bits.
4. Start sourcing the needed bits.
Good luck,
Ron
I had another idea, what about importing from equicar or similar a complete bulkhead/drivetrain from a Tdi? What about importing a whole Tdi truck that was rolled/rear ended?
If you found one LHD (this is not that hard) it would be almost a bolt on.
One more, take pics to document the repairs. This will help if you ever sell and have to explain salvage title.
Old August 29th, 2005, 09:01 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Originally Posted by evilfij
How to start:
This one's easy. Mine's a '94 too and sits 100' away from where his is. Ours were mostly the same. Mine has the rear interior brace bar thingy that the early '94s got and his hood release was on the wrong(right?) side. If a rebuild is in the making then it could sit even closer if I can find room for the rest of the stuff in my garage.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old August 29th, 2005, 10:01 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Does Texas do emissions testing? He can always just toss an edelbrock manifold and carburetor on top for now. That will seriously simplify the wiring. Or, go with something like the MegaSquirt EFI computer if you want to stay fuel injected, but want to save money also. But both of those options may not pass by the inspection guys with flying colors.
But I think that the best starting point is definitely to start figuring out what is bad and what is good.
I highly suggest getting a notebook before you start. Then, grab each known bad part, write down what it is, then toss it. If it's questionable, write it down and set it aside. Save all the hardware, since much of it is oddball metric stuff. A lot of the underhood 'stuff' can be replaced with non-rover replacements for much cheaper if you're willing to take the time and source it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 29th, 2005, 10:29 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Here's my two cents on the rebuild:
Step 1: Unscrew VIN plate
Step 2: Order new "Parts" vehicle from UK (or Germany or wherever) without steering wheel
Step 3: Remove "Parts" vehicle VIN plate
Step 4: Swap VIN plates
Step 5: Attach old steering wheel to new steering column
Step 6: Start and drive "rebuilt" vehicle
If only it didn't cost so much (but some guy WAS selling an '04 until he got scared off).
"It's not a Jeep"
Old August 29th, 2005, 10:50 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Our counties start emmisions testing on Sept 1st. I'm taking mine in tomorrow to get inspected so I won't have to worry about it for a year as I'm sure I'm borderline on passing.
Old August 29th, 2005, 11:22 PM
Hans's Avatar
Hans
Hans Haase
That stinks... was worth a shot.
Oh.... Dillo, you're PM box is full
-Hans
My oil line fix
Old August 29th, 2005, 11:33 PM
I have an idea! He can sell it to me REAL cheap, and then I might have enough parts to keep my 90 running!
Old August 30th, 2005, 12:53 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Good thread!! I was thinking of starting one to see what ideas get tossed in. I really am split down the middle of keeping it for a rebuild despite my complete lack of mechanical skills, or just strip my mods off and buy another truck.
For a rebuild if I could swing it, I would like to do a TDI, but understanding this could prove quite costly, would go to a 4.6 as the second choice just for the upgraded engine. An automatic conversion too would be a nice touch as well.
I have a club meeting tomorrow night and I think a few of the local dealership mechanics are coming out to it so after the meeting I want to ask their thoughts as well since a few of them poured over the truck while it was there.
At the moment I cant start tearing anything off it as the insurance company want to send a "cause investigator" out to inspect the truck closer in the event they feel there is something they need to try to claim against LR.
Chris von C
[/size]
Old August 30th, 2005, 02:34 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I have a 4.0 with wiring harness and ECU. It has high miles but still runs very well, I think it had been rebuilt at some point prior to my owning it. If you want it it's yours, all you'll need is a new air compressor. Let me know if you're interested.
Old August 30th, 2005, 07:31 AM
chrisvonc's Avatar
chrisvonc
Chris von C
Cool thanks David! maybe a 4.0 is in the future.
Chris von C
[/size]
Old August 30th, 2005, 11:01 AM
JBurt's Avatar
JBurt
Jesse McCoy
I love that everybody keeps all their old parts!
I thought I was the only guy out there that was sure I could rebuild that leaking water pump (I know I can too).
Once you figure it out Chris post a list of stuff you need, I'm sure the source members could find most of it in their basements and garages.
"It's not a Jeep"
Old August 31st, 2005, 11:25 PM
chrisvonc's Avatar
chrisvonc
Chris von C
If we go this route and you are willing to devote room in your garage for this, I would be more than willing to go shopping for a shed to put in your backyard if that works for the stuff you would want to move out of the garage.
Chris von C
[/size]
Old August 31st, 2005, 11:38 PM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
Now thats funny right there......
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old September 1st, 2005, 01:41 AM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
We can talk this weekend if you're free. The crew from work are taking out our boats to the Lake on Saturday and maybe Sunday if you're interested in tagging along. We'll be camped out on top of my friends houseboat in Devil's cove with like 6 gross of mardi gras beads encouraging the local college co-ed population to trade with us.
Old September 1st, 2005, 06:28 AM
chrisvonc's Avatar
chrisvonc
Chris von C
Oh man, I am heading back to Philly for the weekend or I would be all over that plan.
Chris von C
[/size]
Old September 1st, 2005, 11:08 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Just ship your truck out to me and I'll install Daves motor and an auto for you as well,
Sorry to hear about this 'flambe' episode.
Of course a diesel would be my recomendation.
JP
legend in my own mind
Old September 1st, 2005, 11:49 AM
chrisvonc's Avatar
chrisvonc
Chris von C
Thanks Jim
got one hanging around?
Chris von C
[/size]
Old September 1st, 2005, 02:16 PM
gtg067i's Avatar
gtg067i
Christian Shea
1997 Defender 90 Wagon
Someone should sneek this bad boy in, not quite yellow...but close enough....
http://cgi.ebay.co.uk/Wolf-Land-Rove...QQcmdZViewItem
I require your largest, cheapest, most alcoholic brewed beverage.
Old September 1st, 2005, 03:32 PM
JBurt's Avatar
JBurt
Jesse McCoy
That's easy to sneek in!
Bring it through Hollywood and pay Mike Myers to drive it through customs
"It's not a Jeep"
Old September 1st, 2005, 04:19 PM
"Just ship your truck out to me and I'll install Daves motor and an auto for you as well,"
Dibs on the old flywheel!
Actually, I can probably round up an auto.
Pendy I'll ship you my LWB and you can put my disco R380 in with CVC's flywheel and everyone will be happy.
rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
sway bar ideas redrover Defender Technical Discussions 10 October 1st, 2004 09:56 PM
CB mounting ideas flippedrover Defender Technical Discussions 21 March 29th, 2004 11:22 PM
