I Phone mounting options - Defender Source
Old June 19th, 2012, 11:47 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I was fooling around with a generic phone/GPS mount and it just didn't seem right. I can't stand having something stuck to the windshield. Someone has to have figured out a clever way to mount a phone. I have a MUD console with a single din head unit. I haven't mounted any gauges in it yet, just the head unit. I was thinking of trying to somehow mount something to the console. If anyone has any pictures of their handy work it would be much appreciated.
Thanks, Jason
Old June 20th, 2012, 12:16 AM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Jason
I went with ProClip based on another member's recommendation and have been very pleased. There's a clip that wraps over the top of the dash (into a vent? can't remember) and a holster that screws to that. Fits my '95 d90 dash... is yours similar?
Clip: http://www.proclipusa.com/store/prod...nt-852583.aspx
Holder: http://www.proclipusa.com/store/prod...er-510164.aspx
Had to contact them directly to order because the website doesn't match on the model search.
Let me know if you want pix.
Old June 20th, 2012, 12:43 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Looks like it makes sense, I will check it out. How's the 90 treating you? I'm finally all fixed up and on the road but far from done
Old June 20th, 2012, 02:12 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
RAM stuff is the best.
Here is their iPhone cradle with just about any mounting option you need.
http://www.rammount.com/NewProducts/...8/Default.aspx
I screwed a RAM mount base into my dash for my GPS....but would work the same with their iPhone mount...will attach a pic in a bit...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old June 20th, 2012, 02:19 PM
http://minneapolis.craigslist.org/ws...078343522.html
So they hold iPhones and guitars?
Old June 20th, 2012, 02:31 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
using a KVM to swap between Mac and Win...argh...have to do "windows" - C to copy...
Edited original link (was looking for a BOSS BF-3...)
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old June 20th, 2012, 02:33 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Pictures of stuff drilled into my dash just for you Horsey :-)
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old June 20th, 2012, 02:38 PM
What's up with all the dust? Do you operate your saw from your front seat or something?
Old June 20th, 2012, 02:44 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Does not look that bad without a flash...considered wiping it down and retaking the pic...but didn't bother.
My top is off from April to November...so it gets dusty and the rain does not wash off the top of the dash like it does the rest of the truck.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old June 20th, 2012, 02:48 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
That makes for a good spot to hang the CB off too. Cool
Old June 20th, 2012, 02:55 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Works pretty good as the CB cord comes through my cigarettes lighter hole...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old June 20th, 2012, 04:15 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Wow impressive collage you got going there Dave.
Jason, here's my set up. They recommend sticking it on there, but I never removed the tape off the sticky tab and it holds just fine. No drilling required. If you can get the wiper to stop in another place it doubles as a road cam. Doesn't swivel and doesn't clip over the top like RAM, but it's a good viewing angle for navigation/texting/stoplight emails/ipod contol.
Old June 20th, 2012, 04:42 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Thanks...not pretty...but very functional...I am sure the purists are hyperventilating...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old June 20th, 2012, 10:51 PM
NomaD110
Christian
1993 Defender 110
It's not an iPhone but rather an iPad but here is what I did...I could see making a similar thing for the iPhone. My radio is the center console and I send audio to it over BT.
I made it using a small lathe and had a friend machine the "head unit" thing from his mill. Done in an afternoon with good plans.
Old June 21st, 2012, 12:37 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Not an iPhone mount but you said you had a MudUK Console? This is where I have one of my GPS units mounted and I find it a perfect location for both seeing and using it. I get less reflection off the screen than in other locations. A RAM mount or something should work and look about the same for the iPhone.
Name:	Console and Fuses.jpg
ID:	53276   Click image for larger version
Name:	Finished panel.jpg
Old June 21st, 2012, 01:31 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Ian, how do you have the suction cup attached. That is pretty close to what I am thinking of doing, I want to keep it a little lower to reduce glare and keep it out of sight
Old June 21st, 2012, 02:03 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I removed the rubber part and just put a bolt through the middle and a fender washer and nut on the back. If you get a RAM or one of the other mounts then just get one of the flat plates that uses screws or bolts. Since you're only drilling holes in the console it shouldn't matter. You can always replace the console front panel later if you decide to go another way. I have a couple of blank spares they sent me for when might I want to change things around later. That GPS unit is about the size of an iPhone and that location is perfect for me.
mount
Custom rack gutter mounting options graves14 Defender Technical Discussions 3 March 16th, 2010 09:44 PM
misc. NEXTEL PHONE mpodgorski For Sale - Parts 5 September 6th, 2006 05:43 PM
Fiberglass hardtop Mounting mjekogian Defender Technical Discussions 1 December 10th, 2005 03:07 PM
Recommendation on a Fire Extinguisher - size, type, mounting, etc. COSteve Defender Technical Discussions 16 April 16th, 2004 02:21 AM
Mounting wing top protectors Chaucer Misc. Chit-Chat 5 March 10th, 2004 07:34 AM
