I need a Box Wrench - Defender Source
Old July 13th, 2016, 09:26 PM
Contractor's Avatar
Contractor
Will
1969 IIA
I need a Box Wrench
Does anyone know where I might find a 30mm, Deep offset, box end wrench?
I have looked at Snap-On, Matco and Mac. I had one ordered from a supplier here in the states, but it was a German tool and I was told a few minutes ago they cancelled my order and refunded my money because of a big back order.
Why is this wrench so hard to find?
Old July 13th, 2016, 09:30 PM
I bought a 30mm socket from Amazon.
http://https://www.amazon.com/gp/aw/...P0L&ref=plSrch
Old July 13th, 2016, 09:39 PM
Contractor's Avatar
Contractor
Will
1969 IIA
I can't make a socket fit for this application, there is not enough room. I need to adjust the valves on my 200, but it's in a Series truck and the room between the radiator and the crank bolt is almost nonexistent.
The only tool that is going to work is an offset box wrench (deep) and it's still tight.
I am of course trying to prevent having to take the front of the truck off. I have thought about trying to roll it back and forth rather than using a wrench to turn the crank bolt.
Old July 13th, 2016, 10:03 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Samstag sales has Stahlwille deep offset box end wrenches - good folks and great tools
STAHLWILLE Tools Catalog Page
and then there is ebay.uk
30mm deep offset wrench | eBay
Old July 13th, 2016, 10:13 PM
speedpin's Avatar
speedpin
Looking ;)
You don't need a wrench. Try this. Jack up one of the front driven wheels (closest one to you), engage a high gear, and turning the wheel by hand to turn the enginend over.
~ Semper Fidelis ~
Old July 13th, 2016, 10:15 PM
Naplm00
Matthew
Avoid all this drama and bump the starter after removing the fuel solenoid wire either using the key or a momentary switch across the starter solenoid
------ Follow up post added July 13th, 2016 10:17 PM ------
Or. This!
Old July 13th, 2016, 11:19 PM
Ignotus
gene
1960 109, w/200TDI
Will, Can't you go in thru the hand crank hole? I use a impact socket on a 1/2" u-joint and ground down my crank handle to fit the 1/2" drive.
Gene
1960 109
1960 88 Ignotus
Blog;
Old July 14th, 2016, 08:05 AM
Contractor's Avatar
Contractor
Will
1969 IIA
Thank you.
Yeah, I can do that....Thanks.
No hand crank hole, Pangolin bumper with a 8274 and fairlead and there is not enough space between the radiator and the crank bolt to even fit a socket.
I'll try turning the wheel or just pushing it back and forth in the driveway first.
Old July 14th, 2016, 09:33 AM
ezzzzzzz
Mark Garrenton
Another option is to get the proper depth socket (clears the pulley) and weld a nut on it. You can use a normal wrench or a gearwrench to turn the engine. Bumping with a starer works but where it stops is hit or miss.
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old July 14th, 2016, 10:01 AM
Offset type only?
Old July 14th, 2016, 11:14 AM
Contractor's Avatar
Contractor
Will
1969 IIA
I can make something home made too, cutting a socket short and welding a handle on it of some sort.
Offset only as a straight wrench won't engage the nut because of the pulley wheel.
The one in Jacks link is honestly exactly what I was looking for.
Old July 14th, 2016, 09:37 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Lift a front wheel and turn it...that's the trick ive used since discovering it in the shop manual...for the '78 LeCar
torque wrench rover4x4 Misc. Chit-Chat 9 December 26th, 2005 02:06 PM
Tip: 32mm fan wrench kolvedic Defender Technical Discussions 4 September 26th, 2005 08:51 PM
Lug wrench - do they really shrink?? paulb Defender Technical Discussions 4 June 26th, 2005 01:42 PM
Oil Cooler Line Wrench Size? Sergeant_V Defender Technical Discussions 5 December 19th, 2004 03:02 PM
