I just did the unthinkable - Defender Source
Old August 22nd, 2005, 06:52 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
After months of looking for some cheap used tires I ended up buying retreads from a company called www.high-tec-retreading.com 4 tires delivered to my door for $290.
Here is a pic of the tire I bought. Did some research on the company and read several truck forums and decided to bight the bullet and go for it.
Old August 22nd, 2005, 07:39 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
You gotta let us know how they hold up. I hope they do well, cause cheap, excuse me - inexpensive, tires are great
"It's not a Jeep"
Old August 22nd, 2005, 07:49 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
My last set was a used set of BFG All Terrains and they held up fine for 2 years. I just dont have the money to spend on brand new tires anymore. The rubber is supposed to be a bit softer than BFG rubber so it should do well on the rocks, nice and grippy. I will keep you informed as to how they handle.
Old August 22nd, 2005, 08:40 PM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
Those tires look good...I would think they would last about as long as the used BFG's you had on before
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old August 22nd, 2005, 08:41 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I keep thinking of trying "green diamonds", a few people I know have used them and swear by them.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 22nd, 2005, 09:01 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
What kind of impact would the "green diamonds" have on rock grip?
Old August 22nd, 2005, 09:04 PM
WCURoverD90
Jason Habbal
What exactly are "green diamonds".....
Never mind....I actually checked the link
Old August 22nd, 2005, 11:03 PM
Hans's Avatar
Hans
Hans Haase
On rock? Good question! I was more thinking about how my current michelins were sliding all over the place last winter. Might actually be a help on rock too, if they are as good as claimed.
-Hans
My oil line fix
Old August 23rd, 2005, 11:45 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I will probably try them (green diamonds) on AT tires for my daily driver disco--I will need to get tires probably in October, and have been "toying" with the idea of using the 35" muds for the D90--the prices are quite nice and if the rubber is a little softer/stickier, even better. I still need to research the whole retread thing for myself before I do, though.
What has me most worried about these tires is that, although truckers use them alot, I see peeled treads on the freeway all the time. For a trucker, you lose the skin and you have 17 wheels left. Me, I lose one on road, and I am going to roll, possibly die. And you see these "alligators" (what we call those tire skins) all the time on freeways. I would say, if you drive 50 miles, you will see at least one. What do you all think?
Old August 24th, 2005, 10:35 AM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
I looked at the retread idea a few years back when I had a disco, for an off road only tire. The research I found, and it was most likely biased but I couldn't find anything to refute it, was that retreads aren't the cause of 'road alligators' any more than regular tires. They claim it all comes down to air pressue: poorly inflated tires will break down and disintegrate when heated under load regardless of the construction of the tire.
check out www.retread.org for all the info you'd ever want on retread tires. Of course since that site supports the retreading industry, you wouldn't expect it to be very negative on retreads My feeling is that they aren't any more dangerous than regular tires. We should all be checking out tire pressures regularly no matter what.
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
Old August 24th, 2005, 11:56 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
FWIW, We run a few commercial trucks -all have retread drive and/or trailer tires. They nearly all wear to legal limits, or suffer sidewall damage, and are replaced before we have tread separation. Steer tires are always replaced with new(not recap).
Old August 24th, 2005, 12:40 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
That is all good info. I am sure there are other retread companies to also consider for large off road tires--does anyone know who they may be?
Old August 24th, 2005, 06:40 PM
I have seen some in the more generic off road mags. I once tested and autoclave (the thing that the tires go into that heats and pressurizes the tire). At the same time they showed me how they can patch a 2' hole in the sidewall on a truch tire! Makes you wonder.
Old August 25th, 2005, 12:19 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
We run retreads on our fire trucks and engines, yes there is a differance between fire trucks and engines We run retreads on all but the steering and tiller axles. I have never in my 17 years on the department heard of a retread coming apart. We have over 200 heavy vehicles driven daily throughout the city and driven hard under emergency conditions. We do take extremly good care of the tires and check the pressure daily. They are changed when tread depth reaches 2/32". I will let you know how mine work when I get them.
BTW I am almost done with my power window install on the 130. I will take some pics and do a short write up.
Kevin
Old August 31st, 2005, 12:39 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Got my tires over the weekend. They look pretty good. The only bummer is that they used Big-O Mud and Snow carcases. I was hoping for BFG. I have a few friends that swear by Big-O so I hope they do well. I will post some pictures when I get them mounted.
Old September 15th, 2005, 10:10 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Here are a few pics of the tires on the truck. Initial impression is very positive
Old November 25th, 2010, 01:51 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Wanted to revive this thread on retread tires as I am considering a set to be used for wheeling. Doing some research I came across this site: http://www.treadwright.com/ and looks like they have a pretty good product. Has anyone used these? Any long term feedback on running retread tires? Side note, I have a set of BFG AT's that I will continue using for daily driving so the retreads will only see to/from the trail duty on the highway
Old November 25th, 2010, 02:13 PM
Holy thread revival!
Old November 25th, 2010, 02:28 PM
Rugbier's Avatar
Rugbier
Gustavo
My biggest fear with retreads off road is what could happen when you air down and the preassure inflicted on the wal where the retread takes place, sounds to me like a recipe for disaster
NO SIGNATURE
Old November 25th, 2010, 05:29 PM
Roving Beetle
Doug
The "new" link is the same company first linked to - new name.
LOTS of people have used these and very very few complaints overall. They seem to do very well aired down and the process they use is really closer to a new tire than an old style "retread" that is glued on. My understanding is that they actually fuse it on via heat etc so really it's not any different than a new tire to speak of.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
