I avoided a major mishap today ...saved by one lug nut.. - Defender Source
Old May 16th, 2009, 06:48 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Not really sure what happened.
I was driving on the highway this morning that was recently grooved for new pavement.
While driving (about 65mph) the D90 felt like it was floating - which was odd as my truck usually handles really well. I thought wow these BFG mud terrains really handle bad on grooved payment...
About 30mins later I hit the exit ramp and the truck started swerving really bad. I thought I must have a flat so I pulled over and inspected the tires the all looked fine - Got back in the truck, bounced over the curb and I heard "thud, thud, thud..." pulled over again and discovered that my rear drivers side tire only had one lug nut on!
I was shocked! I jacked the truck up and installed some spare lugs that I just happend to have.
I am still not sure what happend or why. A couple months back I did remove the rear tire to tighten the half shaft - but do recall installing the lug nuts. I've driven the truck several times since that day.
I am just glad that that last lug nut held on. Kinda scarly....
Old May 16th, 2009, 07:25 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Yikes. Amazing you had spare lug nuts! I has a similar thing happen to me a few years back. I caught it just before it got really bad just as you did. It's scary to think what could've (and would've) happened.
Old May 16th, 2009, 08:37 PM
As a matter of course, I always recheck lugnuts first drive after doing brake or tire work. Glad you are ok.
Old May 16th, 2009, 09:04 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Good to hear you caught it Paul. I experienced similar today with my rear DS. Backed all four bolts out about halfway on the TC side.
Old May 16th, 2009, 10:26 PM
I have had this happen to me after taking a tire to get plugged. I think it was before I had bought a real breaker bar and was using the factory lug wrench. I was lucky and had run to get fuel and wasnt on the highway. Factory lug wrenches are useless Ive broken 3. I am paranoid about lug nuts now, I had some work done on my truck and the lug nuts hadn't been torqued down, dont trust anyone with your lugnuts. I am glad you didnt have an accident.
Old May 16th, 2009, 10:29 PM
D90DRC
D Cantrell
1997 D90SW
I had a similar experience, after installing new QT front arms a re torque of the front L wheel lug nuts was neglected. After leaving the shop I put about 20 miles on it and I jumped on the I15, that did it... Once up to speed 65 mph I felt the dreaded death wobble, I slowed down and pulled onto the shoulder, just at the moment I came to a complete stop bamm the axle hub drooped onto the inner wheel....
Whew i was lucky that night never mind i rolled it 4 months later....
Still waiting for the Hope and Change to start
Old May 16th, 2009, 10:59 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I had my front wheel pass me one time in my old 411 VW
Everything was fine till I hit the brakes then it dropped down onto the blacktop... when I found my wheel it was about a block away
Old May 17th, 2009, 04:01 AM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Happened to me a couple years ago. I thought someone had fu(%ed with my truck, but the lug nuts had just backed out.
Good catch. Glad to hear you are OK
Old May 17th, 2009, 12:40 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Had it almost happen to me about 10 years ago with an old bronco. Developed a routine for installing lug nuts since then, and never had one loosen up on me since.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 17th, 2009, 11:05 PM
Rugbier's Avatar
Rugbier
Gustavo
Originally Posted by JSBriggs
If you guys would keep your bookie paid off things like this wouldn't happen.
-Jeff
NO SIGNATURE
Old May 18th, 2009, 07:48 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
Wow - I did not realize how common this lug nut issue was.
I'll definitely be double checking my lug nuts next time I remove my tires.
Old May 18th, 2009, 10:34 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Thanks guys, I really needed one more thing to worry me as I drive down the road!
Old May 18th, 2009, 10:37 AM
cellulararrest
Chris Snyder
Well we certainly all have one thing in common... It'll never happen to us again! (knock on wood). I'm too anal about my lug nuts now.
Lug nut lock/unlock 97Ariesblu Defender Technical Discussions 4 January 9th, 2008 08:39 PM
Locking lug nut cover Flagg Wanted 4 June 7th, 2006 11:37 AM
lug nut cgalpin Wanted 2 July 7th, 2005 10:05 AM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
OEM locking lug nut kit sheki For Sale - Parts 0 October 2nd, 2004 11:31 PM
» Defender Registry
Hank
D110
90
clb1994
Add your Defender
