humming niose when key is on - Defender Source
Old June 22nd, 2008, 10:25 AM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
When I turn the key to fire up the radio, there is a humming noise (fuel pump?) that I hear. Is it bad to have this noise when the truck is not running?
Old June 22nd, 2008, 11:45 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Where is the humming coming from?
Every time you turn the key to "on" you should hear it from the fuel tank for a few seconds as the pump goes through it's pressurization scheme.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 22nd, 2008, 11:58 AM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Yes, it sounds as if its from the tank, but it keeps humming as long as I have the key "on" (but the truck not running).
Old June 22nd, 2008, 12:36 PM
Hans's Avatar
Hans
Hans Haase
Hmmmm, normally should only go for a few seconds unless the engine is turning. Maybe a stuck relay?
My oil line fix
Old June 22nd, 2008, 01:20 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Thanks, Hans. I will look into this, as I don't think it should keep humming like that. I appreciate the help.
Help! Key Stuck in Ignition - Electrical Problem wadaman Defender Technical Discussions 15 June 19th, 2009 04:38 PM
door key 1997 d-90 hamiamham Defender Technical Discussions 0 June 17th, 2008 11:22 AM
replacing ignition key - 94 snosrfr Defender Technical Discussions 10 June 1st, 2005 01:41 AM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
