Hub and Spindles.. Are they The same - Defender Source
Old October 6th, 2009, 06:00 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Are the hubs and spindles the same on RRC's, disco 1's and D-90's? They seem to look the same. Just curious. I have a rear RRC axle I am building for a 90 and was wondering if they were different..
Legend in My Own Mind.
Old October 6th, 2009, 06:14 PM
i think for certain years within the NAS spectrum, yes. But not all spindles fit all hubs. Spindle has to match hub has to match axle/drive flange if that makes any sense.
Old October 6th, 2009, 06:40 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
the 1987-1989 RRC hubs and spindles are different but the 1990-1995 RRC hubs and spindles should be all "ABS-type" even though some are 10 spline, some are 24 spline.
If you have the earlier hubs and they dont work for you, hold on to them, because I was able to get some $ for mine from a 110 guy who was converting to disc brakes.
Old October 6th, 2009, 08:20 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Jeff has it right. There are basically 2 types, pre ABS and ABS. Either one will bolt up to your housing.
Old October 7th, 2009, 08:17 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
The axle does not have shafts in it but it has a 24 spline carrier. I guess this will be all the same as the d-90 stuff then.
Salsibury rear disc brake conversion merged threadfest Overlander Defender Technical Discussions 159 December 28th, 2016 04:20 PM
Rovertracks new Rover9 superaxle :) Buckon37s Misc. Chit-Chat 8 December 18th, 2008 12:53 PM
Hub nut! TwisteD90 Defender Technical Discussions 22 September 28th, 2004 02:00 PM
