HMMWV 2" Hitch will fit Defender Cross Member - Defender Source
Old October 14th, 2016, 07:38 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
So I've been looking at cheaper alternatives for a simple two inch hitch and i think i found one. The HMMV aftermarket 2inch hitch which uses the pintle hitch mounting holes which should eb the same on the defender rear cross member.
M998 Humvee HMMWV 2" Receiver Hitch Real Carc Paint Best Humvee Hitch | eBay
Am I missing something? Or will this work? Im just wanting one for a bike rack.
Old October 14th, 2016, 07:41 AM
That does not look strong enough, IMO.
Old October 14th, 2016, 07:49 AM
It looks fine for a bike rack, but not for towing.
Old October 14th, 2016, 07:55 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Deleted. Thought he meant the pintle.
KGH - “Stinky LR diesel” Defender Snob
Old October 14th, 2016, 09:11 AM
No need to reinvent the wheel.
Ben (DefenderMD) did the research a while ago and found the '92 Mitsubishi Montero uses the same bolt pattern as the Defender.
http://www.defendersource.com/forum/...eap-57637.html
I (and others here) run it and it's great.
Old October 14th, 2016, 11:19 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Did not know about the Montero option. It good to have more options available! The Montero is a tad cheaper on Amazon, but I don't think you will be able to run a pintle hitch with it.
https://www.amazon.com/CURT-13091-Cl...ype=automotive
Old October 14th, 2016, 11:23 AM
Love having options, but doesn't that hitch look like it's made of like...2mm thick steel? Could that even support the tow weight?
The Montero hitch is 1/2" thick and braced. Just FYI
Maybe there's another H1 hitch that's built a bit better.
Old October 14th, 2016, 11:43 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Even the Montero hitch is only rated for 4000lbs, not enough for any real weight.
Old October 14th, 2016, 11:47 AM
At the risk of sound pedantic, there's a significant difference between 1/2" thick steel, and the spindly steel this homemade humvee hitch is made of.
I'm not sure it's totally germaine that a 4000 lb "2 ton" rating is "not real weight".
It's good info to know that an H1 shares the same bolt pattern as the Defender for the hitch, but I struggle to see how this particular hitch is somehow made more effective by some critical assessment of the Montero hitch.
You may not respect the Montero hitch, but that does not change physics nor metallurgy.
Old October 14th, 2016, 11:54 AM
JohnsD90's Avatar
JohnsD90
I didn't mean the statement as a compliment to the Hummer hitch. I was just saying that 4,000lbs is not enough for the 7,700lb tow capacity of a defender. I cannot pull a car trailer with car on it using a 4,000lb receiver hitch.
Old October 14th, 2016, 12:09 PM
looks beefier for sure!
Old October 14th, 2016, 12:21 PM
Okay for a bike rack, but personally I would not tow with it.
Old October 14th, 2016, 12:26 PM
FlyersFan76
1987 110 Convertible
The one that came on the civi trucks was tied into the rear bumper and frame rails from what I remember.
2011 Range Rover Sport
1987 Land Rover 110 Cabriolet
1997 Defender 90- AA Yellow #1701- Wrecked
1997 Defender 90- AA Yellow #?- Sold
2000 AM General Hummer- Sold
Old October 14th, 2016, 01:33 PM
I guess it depends on what you will use your hitch for. The hitch needs to be tied forward to the frame if you want to use it for anything more than a bike rack or hitch basket.
I pulled a crossmember into a V trying to use a cheesy crossmember mount only hitch as a recovery point.
YMMV your mileage may vary
Old October 17th, 2016, 07:10 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
I think even using the LR style ball hitch that ties int eh frame rails as a recovery point would be risking a deformed rear cross member (mine has evidence of that).
I went ahead and bought the 1992 Mitsubishi Montero hitch from Amazon. Looks pretty slick, just need to get some longer bolts to install it properly
defender, hitch
Which doors fit will fit my '85 Ninety? Paul K Defender Technical Discussions 10 October 21st, 2015 06:29 PM
HMMWV vs DOT/EPA rules? MUDSUX Misc. Chit-Chat 3 November 1st, 2014 09:57 PM
For sale: 1986 m998 hmmwv dbj2003 The Flea Market 12 June 10th, 2013 09:53 PM
HMMWV seats Naplm00 Misc. Chit-Chat 7 February 13th, 2012 11:20 AM
OEM trailer hitch for ROW Defender (might fit NAS too) hillstrubl For Sale - Parts 3 March 18th, 2011 07:36 AM
