Higher strength U-joints? - Defender Source
Old May 26th, 2011, 10:20 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
So far I've put 2 x Neapco 1-0005 Autozone sourced U-Joints (the Made in America ones) in my 90. the rear of the front driveshaft, then 8 months later the rear of the rear. Now the rear of the front has a tiny bit of play in it again... I've greased the hell out of them (probably every few months). But its a bit annoying. Yes its an older truck so these things happen, but I was hoping anybody knew of a source for HD (but OEM sized) u-joints. If that doesn't exist, I may just end up replacing the actual driveshafts with bolt-in HD (larger/CV joints) and calling it a day.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old May 27th, 2011, 06:20 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've used both the neapco and precision, the only two domestic u-joints that fit that I know of (the Spicer 5-4x is NLA) and not seen any difference, aside from price.
There are Hardy-Spicer from the UK.
Actually, I think Tom Woods sells a 1300 series.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 27th, 2011, 08:03 AM
The stock U-joints ARE 1300 series. Tom woods sells 1310 series joints. These are the same as used in Series 3 and early Defender. It is not much difference in size.
edit: But I see YOU knew that... http://www.defendersource.com/forum/...8&postcount=16
Old May 27th, 2011, 02:44 PM
Antichrist's Avatar
Antichrist
Tom Rowe
I meant I think he sells a 1300 series also.
But looking at his site (quickly), I don't see them.
A of couple questions for the OP. It doesn't sound like strength is the issue for you.
When you grease the u-joint, are you pumping in grease until you see new grease from around all 4 seals on each u-joint. If not, that is your problem.
It's imperative that you get new grease coming from under all 4 seals on each u-joint.
Also, when you installed them, did you grease them correctly before installation, or at least after, before putting them in to service?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 27th, 2011, 05:00 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I called them today, no 1300 series u-joints.
To answer your question, yes I've greased them thoroughly upon install, old grease (then a bit of new) coming out of all 4 points. I just gave them a few extra pumps now.
~2008 GTI TSI
Old May 27th, 2011, 06:17 PM
Roving Beetle
Doug
Chances are you have excessive angle issues (or not enough odd as that may sound) if they are not lasting very long. That or they are being stressed on instal?
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old May 27th, 2011, 10:49 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
i don't know, will keep greasing and replacing as needed I guess until I just replace the shafts with something larger.
~2008 GTI TSI
Old May 28th, 2011, 08:32 AM
dchapman
Daniel Chapman
1999 D1
Sounds like you have an issue unrelated to u-joint type.
Old May 28th, 2011, 09:18 AM
Joints wearing is not a size or strength issue. You need to find and solve the root cause....
Old May 28th, 2011, 08:35 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Can I blame nickleback until then?
~2008 GTI TSI
Old May 31st, 2011, 02:30 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Maybe its as simple as a driveshaft not being perfectly balanced, everything else seems pretty tight with no rattles or play.
~2008 GTI TSI
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
Anti Roll Bar Joints TDI Guy For Sale - Parts 3 December 17th, 2004 08:05 PM
weird noise with higher rpm scubadanster Defender Technical Discussions 8 December 13th, 2004 07:32 PM
stronger CV joints Ced Defender Technical Discussions 7 July 6th, 2004 11:48 AM
