Help with RRC Power Steering Pump - Defender Source
Old March 21st, 2016, 03:00 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
Guys:
Desperate for some help here. The power steering pump on my '95 RRC finally kicked-it after singing like a fat lady in an opera and what I thought would be a relatively simple job turned-out to be a stumper.
For the life of me I could nt figure-out how to remove the bottom-most bolt holding the pump/bracket to the engine. I could not see the bold but could feel it but there was no way I could get a wrench or socket on it. I tried everything I could think of for about half an hour and then finally gave-up. Should be noted, I only tried from above but it did not look like there wany any way trying to reach it from below would be better.
Before I give-up completely and take it to the dealer, can anyone offer any tips or suggestions?
CARL
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
Old March 21st, 2016, 03:07 PM
This:
Or this:
Old March 21st, 2016, 03:29 PM
dcproven
David
1977 Series III 88 Santana LR
Just did this, mine was actually loose, but since I replaced all hoses and everything, I put some time into it.
I was able to use a small 3/6 socket with a wobbly extension, for a little bit (from the top) once I got the hoses out. Also when the bolt comes out I had to use a flat wrench, the socket wouldn't fit.
HTH
Old March 21st, 2016, 03:34 PM
a 95 should be the upper of the two pics. there are three bolts. They can all be reached with a box wrench.
Just did one this weekend.
Old March 21st, 2016, 07:06 PM
Green Blood
Carl Phillips
Thanks guys, this was helpful, and yes mine was like the top image.
Clearly, I was missing at least one of the bolts as indicated, but it sure felt like there was one more underneath but maybe not- I'll check with my inspection camera this time.
Also- do you remove the pump from the mounting bracket, or take the bracket out of the truck with the pump still attached? Any difference in approach?
Name:	RRC PSP Annotated.jpg
Old March 21st, 2016, 07:25 PM
Cant speak for others but I pull the bracket with the pump. For me its faster/easier, how we roll.
Old March 23rd, 2016, 11:37 PM
Green Blood
Carl Phillips
I did end-up pulling the bracket with the pump but think this might have been the harder way to go about it. I was able to rotate the bracket clockwise (with a bit of gentle persuasion) to access the bottom most bolt but think it might have been easier to remove the pump from the bracket.
Anyway, it's out and new pump and hoses are on their way.
Thanks again for the support.
Cheers,
CARL
RRC GM power steering pump Baja 90 Defender Technical Discussions 3 February 1st, 2013 03:05 PM
95 d 90 power steering pump Needed Scott 9835 Wanted 2 November 28th, 2006 12:56 AM
Power steering pump johnnyg15 Wanted 0 August 16th, 2006 05:32 PM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
