Help with install - Defender Source
Old January 1st, 2016, 12:27 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Help with install
I wanted to see if there was anyone in the VA area that could assist me with installing my fiberglass hardtop. If anyone is willing to help and has experience drilling the new rivnut locations even better!
I will need to drill in new rivnuts and if anyone has the tool for this I can borrow I will pay shipping to and back from RVA.
I'm willing to pay with a nice bottle of bourbon or couple cases of beer of your choice!
PM if you can assist!
Thanks in advance...Matt
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old January 1st, 2016, 01:25 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
I did mine for the first time this year and it really wasn't hard although I didn't need to install new rivnuts so no experience with that. As for the top itself it is very straightforward just be sure you have someone else to help with the top most piece of the install as it is very hard to maneuver alone.
I have attached the factory directions for the top. Oh last piece of advice based on my install was to put the screws in the top most piece at the windshield header before any of the other top bolts. If you use that as a start the rest can be installed with some minor adjustment if needed. Also be sure to put some strip caulk (3M) around the screw holes at the windshield header to help with water leaking which is common there.
Radio install/wiring help needed. Firefighter2904 Defender Technical Discussions 5 August 8th, 2007 09:39 PM
A/C install help Heath Defender Technical Discussions 4 August 28th, 2006 09:41 PM
How To install Badger Gutter Kit ??? Help TDI Guy Defender Technical Discussions 4 November 5th, 2005 05:41 PM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Install help Joe P Defender Technical Discussions 5 April 1st, 2005 04:27 PM
