Help with Exmod Bayou la batre Alabama - Defender Source
Old July 12th, 2015, 06:17 PM
Himalaya's Avatar
Himalaya
Mark WS
1995 Nas, 86 D110, 97 Hummer H1
My son is broken down inBayou la batre Alabama. He is trying to get home.
He drives a 2.5 Exmod na Diesel. Symptoms are engine really rough and rattly. Sounds like fuel issue.
Anyone experienced enough to diagnose on the ground?
He is trying fuel pump first tonight. But Stephen (safari) feels it might be injection pump.
Old July 12th, 2015, 06:43 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Maybe water in fuel filter? Might want to change it....prime and see how it goes.
Does the IP leak?
If its a lift pump he might be able to make it with an electrical pump installed.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old July 13th, 2015, 12:53 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
What the hell is in Bayou La Batre?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old July 13th, 2015, 09:10 AM
always start with the fuel filter on a diesel. Everyone should travel with spares. It amazes me when someone says "it cant be the filter, I changed that in the past 12 mos". One cup of condensation in a tank of fuel from a filling station and you are stranded.
Old July 13th, 2015, 09:27 AM
Birmabright brotherhood time?
Old July 13th, 2015, 01:28 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Doug is right on this issue. Always carry a replacement filter.
The problem could be he put gas in it instead of diesel. Symptoms sound exactly the same. Ask me how I know.
Old July 13th, 2015, 02:20 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I'm surprised he drives a 2.5 na with the amount of NASs and spendy builds that pass thru your hands.
Old July 13th, 2015, 02:50 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
FWIW this is indicative of shit diesel, I have had this happen a few times in my life. They make fuel treatment additives to remove water from diesel and I would go ham with those, then go fill up at another station. Sometimes the dilution of the water with better fuel will make symptoms reside. Also cetane boost ect in the fuel may help.
Thats a $25 solutionbut after that its most likely that filter, especially on a 2.5NA
Old July 13th, 2015, 03:01 PM
Himalaya's Avatar
Himalaya
Mark WS
Yes. I went over the fuel filter replacement with him. Working on that now. Air cleaner. Then after that will look at fuel pump. Hopefully its only a filter issue.
Poor kid. I don't want him stranded in the bayou. He just passed his Sea Captain training and wants to head home.
I also don't want to add airfare and trucking costs to bring the beastly thing back (truck not my son) if its a minor issue.
Old July 13th, 2015, 05:01 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Does this 110 have a sedimenter?
RDavisinVA
Old July 13th, 2015, 05:12 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
sales pitch
Old July 13th, 2015, 05:18 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Robert.....already pitched the pump/sedimenter/filter housing to him. Your slipping ......lol....
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old July 13th, 2015, 05:19 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
FWIW if it is the fuel these symptoms will persist with the filter change. See if the shop will drain the fuel and then he can refill.
See if his last action was to refuel the tuck
Old July 13th, 2015, 06:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by NPT90 View Post
sales pitch
The first troubleshooting step is to disconnect the fuel line coming out of the lift pump and see if fuel squirts out when the engine spins over.
Second. Check the fuel flow out of the filter before the IP.
Then you decide to change the filter or not.
The risk with changing the filter, if it is the sandwich style, it is very very easy to twist one of the large round seals and suck in air... end of game scenario.
With a sedimenter (to go back to the original question), it can be drained.
When drained it is very easy to see water, and diesel engines will not run on water.
Since the first 2 troubleshooting basic steps were possibly skipped, we have no "arm chair quarterback" advice from afar unless the filter has not been changed yet.
If you want good advice, I can PM you my cell and talk through solutions with the new captain.
RDavisinVA
Old July 13th, 2015, 06:37 PM
Its probably the spark plugs or crank position sensor.
Old July 13th, 2015, 10:44 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Who??????
RDavisinVA
mod
Help decoding exmod 3.5 engine number akrockhound Defender Technical Discussions 12 December 3rd, 2014 02:57 PM
Alabama miniac Trips, Trails and Events 7 December 1st, 2011 10:55 AM
Alabama miniac Trips, Trails and Events 43 September 13th, 2010 09:09 PM
WTB truck cab , roll bar LR 90 Alabama miniac Wanted 7 June 6th, 2010 12:49 AM
Ex-Mod 110 in Alabama moose The Flea Market 2 September 26th, 2008 08:01 PM
