Help Speed Limiter - Defender Source
Old May 6th, 2004, 12:22 AM
Help Speed Limiter
I need the speed limiter gone, NOW. 94 D90
Please tell me how. I am constantly hitting it. It is really annoying.
Ron
Old May 6th, 2004, 12:42 AM
How fast are you going? If it is due to bigger tires and regearing then I would say you need to change the little gear in the T-case that is connected to the speedo cable. The speed sensor is required for the ECM, so no speed sensor = nogo for you rover V8. I'm not sure you but you may be able to reprogram the ECU.
Old May 6th, 2004, 01:39 AM
89mph
I wish to go faster. That is like average speed on the turnpike. BMW has me spoiled.
Ron
Old May 6th, 2004, 02:27 AM
disconnect the speeedo
Old May 6th, 2004, 09:33 AM
HMMMM, I can do 95mph on the down hills.
Old May 6th, 2004, 11:53 AM
Abrooks's Avatar
Abrooks
Tony Brooks
My understanding is the the cold start disco chip removes the limiter. Granted, I never hit it before, so I have no first hand experience.
Old May 6th, 2004, 11:00 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I've hit it trying to catch up to Trevor with his 4.6 Disco. And a few other times too. Mike where you in neutral??
Jimmy Buffett
Old May 7th, 2004, 08:09 AM
No I was in 5th.
Old May 7th, 2004, 08:28 AM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
I saved this email from Doug Aitken on the D90 yahoo group because I thought I'd want to get this chip after I regeared (someday):
"I finally got round to swapping out my EPROM for the "Cold start" EPROM for a 3.9 ('94, '95) Disco to get rid of the annoying speed limiter which kicked in at just over 70 mph with my 4.10 R&P......
It could be purely psychological, but it seems like the engine runs much smoother and pulls better throughout the rev range (as well as the removal of the "brick wall"!).
Anyone else who has done this mod notice the same thing?
BTW: The part number has changed on this item: used to be PRM 3360A: it is
now PRM 3652.
Doug A"
Supposedly, it only costs like $17 dollars, and that's from the dealer. Be sure you don't get the 4.0 chip, it's for GEMS and is more expensive (and won't work!)
Good luck
Old May 7th, 2004, 08:30 AM
souza's Avatar
souza
Dave Souza
Another note on this... I've been with other Defenders that have no speed limiter to speak of, particularly my buddy's '94... But I hit the speed limiter on my '95 anytime I get over about 86 MPH (which hasn't happened once since the swampers went on). Seems weird that some have it and others don't.
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
Old May 7th, 2004, 10:04 AM
BTW my 90 is a CND (Canadian) so that may be why it does not have the limiter.
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
AC Fan Speed Knob Missing...Argh! boshea Defender Technical Discussions 7 February 17th, 2006 09:55 PM
Defender fan speed switch used draaronr For Sale - Parts 0 January 1st, 2005 11:22 PM
speed sensor wiring rcork Defender Technical Discussions 2 July 27th, 2004 09:44 PM
