Help lr3 tailgate won't open. - Defender Source
Old December 20th, 2014, 09:18 PM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
Hi Guy's
My wives 2006 lr3 (lower) tailgate won't open. i researched online and found a lot of the actuator problems. But this is not the case with ours. The upper opens, the lower is stuck. the right side is open but the left side is locked tight. i tried force etc no luck!
Any thoughts?
The dealer is 800 miles away so no option there
Old December 20th, 2014, 09:33 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
FWIW, mine (08) did the same thing. Upper opened just fine, lower wouldn't open. Difference was, both sides were stuck. I think you need to remove the carpeted panel & replace the linkage between the latch & the actuator.
Good luck! (Have you tried the D3 forum?)
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old December 20th, 2014, 10:12 PM
Skeena river rover
jeroen
1997 300 TDI 110
Thanks. No not tried the d3 forum i might try that forum to.
Thanks for the reply.
Old December 20th, 2014, 10:15 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
This may help
http://www.roverparts.com/TechTips/T...t_Open_LR3.cfm
Old December 20th, 2014, 11:00 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
http://www.disco3.co.uk/forum/
Old December 21st, 2014, 01:31 AM
Skeena river rover
jeroen
1997 300 TDI 110
Thanks guy's!
Old December 21st, 2014, 05:12 PM
Skeena river rover
jeroen
1997 300 TDI 110
Thanks to a forum member (roverman) i got it open!
Old December 21st, 2014, 05:26 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Your welcome, now you know how and you got the carpet off get that stand-by upper latch opening cable fitted.
Cheers
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
lr3, tailgate
Door won't open from inside ontheway Defender Technical Discussions 9 January 13th, 2013 08:23 PM
OPen loop stall, or at least I think it is open loop! Neo Defender Technical Discussions 18 January 25th, 2012 11:34 AM
Key won't open door - missing part JFD Defender Technical Discussions 2 July 3rd, 2011 07:38 PM
Won't crank, Won't start. revor Misc. Chit-Chat 4 September 16th, 2010 09:48 PM
doors won't open WhiteD90 Defender Technical Discussions 5 November 27th, 2008 01:26 PM
