Heater not working - Defender Source
Old November 30th, 2008, 05:33 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
Heater not working
It is cold in Denver, and my heater (or the blower??) isn't working. The AC blower works great, but the lever on the right of the steering wheel is all the way down, and no air is being blown out. What part to I need, and how difficult is it to repair myself?
thanks
Old November 30th, 2008, 06:26 PM
I am sure you have done this, but check the fuse.
Old November 30th, 2008, 06:51 PM
JRW's Avatar
JRW
94 D90 ST #1247
You may also want to pull off the vent cover on the Passenger wing and try to manually turn the fan motor. Mine accumulated some water and has siezed...
Old November 30th, 2008, 07:00 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
mine, i have to wiggle the lever once its down for it to work
3rd low and BOOT IT
Old November 30th, 2008, 10:39 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I was recently doing some work on the ignition switch in the dash and when I finished playing around in there I noticed my control for the blower didn't work any more. I ended up opening the dash again and pulling the control level to try cleaning it. Once I re-assembled it, the blower worked as usual.
....Not really sure what I did that fixed the blower, but I guess it was something to do with a connections in the lever.
Old December 1st, 2008, 08:36 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
Its the fuse...
So I go into the fuse box, and their isn't a fuse in the socket. When I tried to replace the fuse, I found that the fuse socket is completely fried out. It won't hold the fuse anymore. So what do I need to replace? The entire fuse panel?? I am guessing THAT is a pain in the ass, not to mention expensive.
Also, I am guessing that the heater motor has gone bad (hence why it fired the fuse socket) would that be a good guess as well?
thanks everyone!
Old December 2nd, 2008, 09:35 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
did a quick inline fuse and the heater is working again Just glad the blower motor wasn't blown...
I can see that putting in a new fuse panel would be a PAIN in the ASS
heater
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
Rear Window Heater Help mwmcgehee Defender Technical Discussions 0 August 21st, 2004 01:40 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
