Heated Windscreen Replacement - Defender Source
Old March 8th, 2010, 01:14 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I need to get a new windshield on the 90 and was planning on going through insurance.
Has anyone had insurance replace their windscreen with a heated one? If you were to do this would you need the wiring and switch in place before you had the windshield folks do the job or could you do it after?
Alex
Old March 8th, 2010, 01:49 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The tags are on the bottom of the screen for the later ones, and on the top for the early ones, but they're fully accessable on both (top fitting you need to pull the rooflining back a bit after removing the sun visors), bottom ones you run the cables through the back of the dash... it's easier & neater to whip off the dash top panel (about 10 screws) and then you can lay the cables underneath it, zip tie them up all neatly then refit.
Old March 16th, 2010, 08:42 PM
bjp
Brent
1995 D90
Anybody else in the states carry Heated Windscreens besides RN? Tried the usual suspects with no luck. Anybody with Military takeoffs?
Old March 16th, 2010, 10:40 PM
Have you read this thread?
http://www.defendersource.com/forum/...ad.php?t=12013
You can install the wiring etc after the windshield, which is easier if you get the new type with the contacts on the bottom instead of on top.
Old March 16th, 2010, 11:06 PM
bjp
Brent
1995 D90
I did great info. They do not have any in right now and when they do come in they are the more expensive kind. That combined with shipping to CA I might as well just order from uk. Trying to cover all bases here in US first and going through the Insurance so the quicker the better.
ac
windscreen replacement in San Francisco bennett Defender Technical Discussions 5 January 18th, 2010 11:46 PM
110 Heated Windscreen RyanS Defender Technical Discussions 30 September 29th, 2009 12:45 PM
Price drop on heated windscreen glass Overlander Defender Technical Discussions 7 August 14th, 2006 10:47 AM
Heated Windscreen Wiring TDI Guy Defender Technical Discussions 4 August 30th, 2005 12:00 PM
Windscreen ideas Mike Hippert Misc. Chit-Chat 40 July 9th, 2004 02:38 PM
