Headlights - Defender Source
Old December 30th, 2003, 11:30 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Headlights
Anyone running these (Hella H4 replacement bulbs) or something similar?
https://www.expeditionexchange.com/hella/
EwS
Old December 30th, 2003, 11:46 PM
tbmcneill
Guest
Posts: n/a
I'm running the H4s ... big improvement over stock. Price them out, though. I found mine at 1/2 retail from a local garage.
T
Old December 31st, 2003, 12:46 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Yes, they're great. Dunno what it means, but I think I remember mine being iCODEs.
Old December 31st, 2003, 01:45 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Great!
Thanks for the input guys!
EwS
Old December 31st, 2003, 06:29 AM
I have sylvania xtravisions.
The were like $25 for the pair.
If you get the hellas make sure to seal the bulb holder real good, otherwise they look like fishbowls. I have seen this on a couple trucks. Xtravisions are sealed. I had them next to the hellas and they were similar. The main difference was the pattern of the light. Hella was a much sharper cut off.
Ron
Old December 31st, 2003, 09:03 AM
E-code = European code kinda like DOT I think. I have the Hella E-codes, they are much better then stock.
Old December 31st, 2003, 12:18 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Is anyone running these on their daily driver. It said that they weren't DOT approved. Would it be obvious enough that you could get pulled over and ticketed? I hate the stock lamps.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old December 31st, 2003, 12:38 PM
Nearly a year on my 90 and I have not been pulled over once for them. This is my only ride.
Old December 31st, 2003, 03:33 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I have had them on my truck for about two years. I did not know they were not DOT approved. THe light output is much better than stock and I have had no problems with the police.
Old December 31st, 2003, 09:05 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I ordered up a set from rallylights.com. Should be here next week. Aout 75 for 2 headlamps and bulbs. Looking forward to next tuesday
ht, lights
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
installing Hella headlights oldscratchggf Defender Technical Discussions 5 December 25th, 2005 10:16 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
2 Defender headlights Disco_Stu For Sale - Parts 5 September 28th, 2005 11:59 AM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
