Headlight How To - Defender Source
Old January 6th, 2015, 04:06 PM
aquatiger's Avatar
aquatiger
S
none
Headlight How To
I didn't quickly come across a How To for Headlights, so I thought I'd share some pictures of mine in case someone wanted to know how easy it is to change them. If anyone wants to add something or correct my mistakes, I'd appreciate it.
First, an overview. These are the 8 screws you need to remove to get the outer panel off:
The upper outer lights come out with a long screw:
The lower outer screws have two sets. One set outside, and one set inside once you take the light out:
The last set I took out were along the medial side of the panel:
Once you get that off, you'll see the light inside it's housing. You only need to take out one screw to get the headlight out:
Name:	screw position.jpg
The other screws at 9 and 12 o'clock are to change the light position. If your lights are aligned appropriately then don't touch the screws at 9 and 12 o'clock.
The little housing are held together with some tabs:
You just line those up and attach your new headlight. Then reverse the order. I hope this was helpful.
ID:	110277   Click image for larger version
Old January 6th, 2015, 04:08 PM
aquatiger's Avatar
aquatiger
S
none
Some of my pics came rotated. If anyone knows how to fix that please let me know! Thanks
Old January 6th, 2015, 04:42 PM
Edit
ht
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
how to change headlight chirider Defender Technical Discussions 9 November 25th, 2004 05:59 AM
Headlight Guards RX6RCROL Wanted 5 September 17th, 2004 12:25 PM
94-95 headlight switch.. can be broken TDI Guy Wanted 4 May 17th, 2004 06:28 AM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
