Ham Radio - 2m/70cm mobile antenna recommendation? - Defender Source
Old February 1st, 2016, 09:13 AM
Looking for a decent ( but not expensive ) 2m/70cm ( and maybe 6m ) antenna setup for my NAS d90 ... will connect to a Yaseu VX8-DR handheld.
Any recommendations?
Old February 1st, 2016, 02:16 PM
Rugbier's Avatar
Rugbier
Gustavo
I had this mounted on the license plate light bracket, worked awesome
Diamond Antenna Dual Band HT Antenna (2m/70cm)
NO SIGNATURE
Old February 1st, 2016, 02:51 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
I've got this mounted on the swing away tire carrier. The cable is small diameter, so it can be run along the same path and through the same holes as the wiring for the third brake light.
Cabling is Diamond Antenna C213 Coaxial Cable
Assembly. Antenna mount is Diamond Antenna K540 Mobile Antenna
Antenna is Diamond Antenna NR770HB Dualband VHF/UHF Mobile Antenna.
Old February 1st, 2016, 10:17 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
The NR770h is always a great option for dual band. Not too pricey (~$50) and a bunch of mounting options. They're also pretty rugged as it's not too tall and just a single coil in the center for phasing on 440.
Diamond® Antenna ~ NR770HNMO Dualband Mobile Antenna
1/2λ (3 dBd) on 2 meters and 2 phased 5/8λ (5.5 dBd) on 440
Old May 15th, 2016, 12:01 PM
I am running a Larsen NMO 2/70, but if i were to do it again, i would have bought a Laird NMO C144/440 instead. My HF antenna is a Laird CB27 and I am impressed with the construction of the Laird.
Old May 15th, 2016, 02:42 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I don't have an antenna to recommend but I will strongly suggest you buy one that will directly connect to your radio so you avoid adapters. Also, if you go with a mag mount you have a limited number of places where it will stick!
Old May 15th, 2016, 03:19 PM
I made a bracket and attached a Diamond NR770HNMO Dualband Mobile Antenna to one of the light tabs on the front of the eco-cage. If you want pictures, please let me know.
radio
New Mobile browsing option | Mobile skin Janet H Community News & Announcements 0 March 3rd, 2015 02:30 PM
2m or 2m/70cm mobile radio javelinadave Wanted 7 April 22nd, 2013 07:10 PM
HAM / GMRS antenna ? Rugbier Misc. Chit-Chat 4 October 19th, 2011 05:40 PM
ARB CB/HAM Antenna mount - used dmarchand For Sale - Parts 9 December 31st, 2009 12:46 PM
» Defender Registry
Kermode
StuartL
Landy
x-pat
Add your Defender
