Gullwing window door Upgrade - Defender Source
Old September 10th, 2012, 03:24 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Has anyone put a gullwinch rear window on their Defender? Looks good and is very useful. Price is steep.
http://www.ebay.com.au/itm/LAND-ROVE...#ht_5716wt_963
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 10th, 2012, 03:33 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
I know some comapny just started making something similar for Land Cruisers. They replace the rear sliding windows and are like this, however they can be fully removed also. Don't really like the fact that these take a couple inches off the bottom of the window either
Old September 10th, 2012, 03:50 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
cool idea, but $$$.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
very cool though
Mark Kellgren
KM4BOR
Old September 10th, 2012, 04:04 PM
OK 'splain me why these are not the dumbest idea. From what I can see, you can only open them from the OUTSIDE. which means they can only be open when the vehicle is stopped or if you don't mind the risk of having a window torn off while driving.
Old September 10th, 2012, 04:05 PM
ini88's Avatar
ini88
Daniel Marcello
Yeah, I wish the glass went to the bottom.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 10th, 2012, 04:07 PM
would have thought that some RV replacement window could perform the same function
door, window, wing
Window seals for Fiberglass Hard Top (wanted) wildenbeast Wanted 1 November 1st, 2005 10:55 AM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
Soft Top Side Window Bar boshea Wanted 2 June 18th, 2004 08:14 PM
st driver&passenger window bases fill with water Marc Weinstein Defender Technical Discussions 6 April 15th, 2004 06:52 PM
Window rattle ? Hammertime Defender Technical Discussions 3 April 13th, 2004 04:08 PM
