Guess the part - Defender Source
Old February 18th, 2007, 07:48 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
Guess the part
I just did some major dissambly on my defender, it was pretty much uneventful except this one piece, shown below, along with some of the carnage it caused... looks like i'll be going back to sears this week to do a tool exchange!
note the snap-on t40 is now permanetly attached to the previously hex head.
surprisingly the hex didn't strip out, but after breaking three allen keys i had to try something else out, queue airpowered hammer tools.
Old February 18th, 2007, 08:44 PM
mmm, parking brake drum retaining screw. hate 'em
Old February 18th, 2007, 09:25 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
nope, although i had a problem with that when i replaced the rear output shaft of my transfercase. I wound up drilling it out.
To be honest i don't think i've ever succesfully removed a phillips head retaining screw for any brake parts. My acura had the same problem...
Of course i never replace the retaining screw they make me so mad
Old February 18th, 2007, 10:49 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
That's most of the bolts on my CJ-7, I hate the silly things.
Random guess... windshield frame?
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 18th, 2007, 11:15 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
That's my guess too.
Old February 19th, 2007, 05:09 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
nope, the bolt is about 24 millimeters long.
Think a huge kind of dissasembly project.
Old February 19th, 2007, 08:00 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Could it be one of two bolts on the left front of the engine, behind the power steering pump/alternator, that bolt into the head? I believe they mount the lifting eye. It should be hidden by the alternator mount. How'd I do?
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old February 19th, 2007, 08:31 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
that's my guess too.
Old February 19th, 2007, 09:00 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
yep, it's the bolt directly behing the power steering pump. I couldn't believe it didn't strip, and managed to destroy the allen wrench instead, it's usually the other way around... I'm still trying to figure out how to get my tool out of it, and what to replace it with.
Old February 19th, 2007, 09:52 AM
No wonder I couldnt get it - its a V8 question. I was set up for failure!
Old February 19th, 2007, 10:20 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
muhahahaha, yes my secret vendetta against non-v8 rovers has been exposed!
Old February 19th, 2007, 11:43 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
Originally Posted by JSBriggs
To get you tool back, you need to tighten the bolt into somthing. once its tight your tool can come loose. Usually you can then untighten the bolt again and the tool wont get stuck. The other option is to put the bolt in a vice and then turn the tool clockwise.
-Jeff
we had to used a air hammering tool to get the torx bit in there, we tried to pull it apart, but had no success, i'll probably just put it in my "broken things that i keep for sentimental value pile"
Old February 19th, 2007, 11:53 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
FWIW, those bolts are always a PITA. I have found that if you take out every other bolt in the bracket except that one and use a hex socket and apply modest force counterclockwise while tapping the lift eye with a hammer in a counterclockwise direction, the whole assembly will rotate a little bit and the bolt will come loose.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
part
part #'s for a 94 jimmy salmon Defender Technical Discussions 3 March 27th, 2006 10:10 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Anyone have this part Campbell Defender Technical Discussions 2 May 10th, 2004 07:01 AM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
