Got Rust? - Page 2 - Defender Source
Old March 22nd, 2013, 12:29 AM
grnthng, do you have more pics of the rear repair on your truck? I need to do that to my lwb.
Old March 22nd, 2013, 08:01 PM
grnthng's Avatar
grnthng
Luis A. Costa
'93 Range Rover County LWB
Yhea! Its not as big a deal as I thought it would be....takes a while to drill out all the factory spot welds! Be extremly carefull not drill through your fuel tank!
You will have to unbolt all your body mounts to lift the body to give yourself workspace.....just remove the nuts from the bolts and leave the bolts and bushings in place!
Assuming you haven't stripped down already!
One more thing, after you start aligning the new cross member you will have to temporaryly hang the tailgate on to align and then you can begin or tack welds....then remove the tailgate and weld the rest!
I missed this step and almost screwed the whole thing up, luckily I was able to adjust the bolts on tailgate to align it....but its still a little off to one side!
Hope this helps!
ID:	68724   Click image for larger version
ID:	68726   Click image for larger version
ID:	68728   Click image for larger version
ID:	68730   Click image for larger version
Rust Question Rob Defender Technical Discussions 0 August 29th, 2004 01:40 PM
fix for rust on rear crossmember/bumper d90_1372 Defender Technical Discussions 2 August 6th, 2004 08:38 AM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
