Gearbox miles? - Defender Source
Old January 5th, 2013, 06:21 PM
Gordonhurst
Mark
Gearbox miles?
Looking at a 1995 D90 which has 240K miles. Engine and clutch was replaced 30k miles ago...but I'm concerned about how much life left in the gearbox or other drivetrain components. Should I be?
Old January 5th, 2013, 08:37 PM
That thing should come with a filing cabinet of receipts. There is no question the gearbox or transfer case has been replaced at some point.
Old January 6th, 2013, 08:30 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
It really depends on how it was driven.
The R380 in my '95 Disco had 265k miles on it when I pulled it out (for things unrelated to the gearbox). It was just starting to get a little worn in the baulk rings. The output shaft had light wear.
On the other hand I've seen 100k gearboxes with heavy wear on the splines.
The transfer case was fine (except for corresponding wear at the input..
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Odometer reads 76% actual miles stevewhitaker Defender Technical Discussions 4 January 21st, 2006 06:07 PM
'97 Defender LE - Low Miles Weaver For Sale - Vehicles 1 May 24th, 2005 08:22 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
01 Disco II 14k miles lots of Mods Disco-HOG For Sale - Vehicles 1 November 27th, 2004 11:29 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
