Gauging Interest In Rear Swivel Clevis Tabs - Defender Source
View Poll Results: Yes! I would a pair of those killer swivel tabs!
Bolt on (threaded rear end with grade 8 hardware) 1 50.00%
Quick release pin 1 50.00%
Voters: 2. You may not vote on this poll
Old March 10th, 2010, 11:11 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I am getting ready to pull the trigger on having my Wolf Fab Rear Swivel Clevis Tabs milled. These will slide into the holes in the rear crossmember and bolt on the back side. Another option is to have a quick release pin so you can pull them out if necessary. The tab will accept standard 5/8" D-rings (3/4" pin) with a 10,000lb working load. Cost will be about $100 a pair SHIPPED. Clevic tabs NOT included. The prototype photoe below is actually about 3" shorter that the final verison.
If you are interested, please chime in.
Semper Fi!
Old March 10th, 2010, 11:36 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Depending on the Diameter, I am interested. I don't need them for the rear, but if they will fit the openings in my front bumper, I would like a set.
Old March 10th, 2010, 02:56 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
That is a cool product!
Old March 10th, 2010, 02:58 PM
Wolf Fabrication
Sterling Archer
'08 D3
What material are they made from? Are they held in place with the the standard bumper bolts and washers? Will that allow them to swivel in the hole or will they be fixed?
-Jeff
I have not decided on final material just yet. They will either be held in place by the provided grade 8 hardware, or some type of removable pin. They will be avle to swivel in the hole.
Semper Fi!
Old March 10th, 2010, 03:47 PM
I like the idea. Is the bumper strong enough for those kind of loads at that point? I'd need to run out and look to be sure, but I don't think it's completely braced around that hi-lift hole is it?
I know the NAS bumper uses them, but it also mounts along the center and the far corners as well.
Also if you let them swivel, I think rusting on the cross member side will be an issue regardless of the material you use for the pin.
Old March 10th, 2010, 04:03 PM
Wolf Fabrication
Sterling Archer
'08 D3
The holes are right next to the frame. Plenty strong. Coat the swivel in grease before inserting to prevent rust.
Semper Fi!
Old March 10th, 2010, 05:25 PM
Yeah I agree, it looks as strong as any other part short of a big backing plate. I vote for a quick release then because it will require re-greasing to prevent rust.
Old March 10th, 2010, 05:44 PM
Wolf Fabrication
Sterling Archer
'08 D3
Sorry I meant to type that clevis shackles are not included. They seem to run about $13 from McMaster-Carr.
Semper Fi!
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Barnett Childress chrisvonc Defender Owners 0 February 29th, 2004 12:47 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
