Gas Storage--Gone Bad? When will gas go bad in a Jerry Can? - Defender Source
Old August 25th, 2007, 01:32 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up Gas Storage--Gone Bad? When will gas go bad in a Jerry Can?
How long will Premium Fuel last when stored in a quality steel Jerry can before it goes "bad"--or becomes harmful to put in the tank?
My Wedco Jerry can is advertised with "Petrol resistant Alkyd-Ammonia based lining to prevent internal rusting" and is made form 0.9 mm steel construction.
Paul
Old August 25th, 2007, 03:56 PM
Abrooks's Avatar
Abrooks
Tony Brooks
If the tank is full, much longer than if it isn't. However, some sta-bil added to the gas will help a lot. In fact, the current tank of gas in the defender was sitting in the Bentley's old tank for 6 years with some sta-bil added -- it's running fine.
Old August 25th, 2007, 08:34 PM
Captainruss's Avatar
Captainruss
Russ Bowles
03 Disco II
The problem with gas today is the ethanol that is added. It will sludge up and gel fuel the longer it sits. Sta-Bil may help stave it off for a while but it is inevitable that it will happen eventually. You can't let fuel sit for as long as you used to.
'03 DII, lotsa' RTE, a little Southdown, and some of my own fabrication
Old August 26th, 2007, 12:48 PM
pcscharfe
pcdefender
D90/NAS 110
Question
Thanks guys!
I have the tank completely full--but I still need to know how long before it will do harm to the engine--I would think that there must be a pretty definitive answer?
Is it a few weeks.... a few months.... years?
Thanks!
Paul
Old August 28th, 2007, 09:31 PM
pcscharfe
pcdefender
D90/NAS 110
Bump. No definitive answer?
Old August 29th, 2007, 08:32 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
If I were to risk it and make a statement to answer this question I would say the life of gasoline should be limited to 6 months or less, 3 months would be the normal shelf life of commercial gasoline in the nations fuel distribution system .
There are summer and winter blends of gasoline as well as regional blends, all these factors come into play. Oxygenates (Ethanol as mentioned above & MTBE) can vary from region to region.
Stabil will definately help extend the life.
Best thing to do is put it in your tank every 3 months and refill the Jerry can.
Old August 29th, 2007, 08:40 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Okay, it is not definative, but here are a few links to read to help you decide. Sources vary, so add the necessary grain of salt where needed...
http://www.straightdope.com/columns/060825.html
http://www.alpharubicon.com/altenergy/gaslifepal.htm
http://theepicenter.com/tow021799.html
~Scott T.
'95 D-90 ST - AA Yellow
Old August 29th, 2007, 05:42 PM
pcscharfe
pcdefender
D90/NAS 110
Thanks Scott(s). That was the info that I was hoping for--it sounds like I can sleep at night if I refill the tank every couple months and avoid the need for additives all together. Much appreciated for the input and the links!
Paul
gas
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Gas Boycott, interesting read draaronr Misc. Chit-Chat 7 April 7th, 2005 11:43 AM
Need replacement locking gas cap vnrover Defender Technical Discussions 17 April 10th, 2004 04:29 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
