Garage hoist/rail system - Defender Source
Old July 26th, 2011, 10:17 AM
Does anyone have one of these and give their thoughts, or know of good sources for them at a reasonable price?
It's basically a rail (or perhaps I-beam if you want to go beefier) and a trolly with a hoist on it. I'd like to install one to give me the ability to lift things into a loft/storage area but would like it to be beefy enough to also lift a drivetrain if needed.
I haven't checked lately but I know Tractor supply has barn door rail systems like this, although I am unsure of the load they can handle. I believe the one shown in this picture is from Harbor Freight.
Originally Posted by pendy
I'm here for the D's
Old July 26th, 2011, 10:47 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Wouldnt the various systems show their numbers.
Old July 26th, 2011, 10:52 AM
They do. It looks to be 450 or 600# depending on the mounting. How much does a engine/transmission/t-case weight?
Old July 26th, 2011, 10:57 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I bet close to 600lbs!
Semper Fi!
Old July 26th, 2011, 11:03 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Weight 560 if all new parts with no oil or spinny bits bolted to the engine. Well over 600 fully dressed.
Eric
------ Follow up post added July 26th, 2011 11:05 AM ------
Why not just do an I beam and chain pulley system seams a used tool shed should have the bits for cheap.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 26th, 2011, 11:07 AM
Naplm00
Matthew
Well, harbor freight sells a 1k and a 2k beam trolley
http://www.harborfreight.com/1-ton-p...ley-97392.html
of these and a chain hoist, you would be good to go
http://www.harborfreight.com/1-ton-chain-hoist-996.html
then all you need is a beam
they also sell a premade gantry crane, with a 20% cupon its not all that bad
http://www.harborfreight.com/1-ton-t...ane-41188.html
Old July 26th, 2011, 11:10 AM
Yes, I think I should go for at least 1-ton capacity and an I-beam, although a 30 ft long I-beam sounds expensive. I'll have to see what local steel shops want for one.
Old July 26th, 2011, 11:47 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
and you probably should've talked to your contractor about this before the walls were built!
Old July 26th, 2011, 11:50 AM
I didn't think about the fact the storage area would be so friggin high! The beam can hang from the ceiling joists and the load will be spread across the roof. I don't think there will be any issue there. Unless you are thinking for another reason?
------ Follow up post added July 26th, 2011 11:52 AM ------
Oh and I assume I can get some kind of baby I-beam that is lightweight since no span needs to be any more than 16" if I hang it from every joist. At least I hope so. Thats why I was looking at those channel style systems as they are very light.
Old July 26th, 2011, 01:33 PM
Yes I did, and I will, thanks.
Garage Cleaning - Everything Must Go!! m.michaels For Sale - Parts 13 February 7th, 2006 03:02 PM
Piaa 90 Xt Pro Dual Lamp System bruinlad For Sale - Parts 2 March 21st, 2005 08:36 PM
Double "S" Stainless Steel Exhaust System edducati Defender Technical Discussions 11 July 23rd, 2004 10:43 AM
rail system hooks & anchor point mounts paulb Defender Technical Discussions 2 November 24th, 2003 01:16 PM
