Garage Heater Recommendations - Page 2 - Defender Source
Old January 12th, 2013, 01:21 AM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
I Run the in floor hot water and love it. You don't loose the heat every time the door opens but would apply to new/renovating construction. Wouldn't recommend infer red however as you feel sunburned at the end of the day.
Old January 12th, 2013, 09:12 AM
jac04's Avatar
jac04
Jeff
Currently Roverless
I bought an Oulette OCH4000 240V heater from Northern Tool. It was on sale for about $70 delivered to my door, which was down right cheap, so I almost had to buy it. It is 4000 Watts (roughly 13500 BTU IIRC), so it's not going to heat up a big shop quickly. I have a 12' x 25' area of my garage sectioned off for winter work & storage, and it does a nice job heating that area. The electric furnace also helps minimize the humidity in this area (unlike an unvented propane or kerosene heater).
For the remainder of my 36' x 36' garage, I use a 75,000 BTU/hr propane forced hot air furnace .
Old January 12th, 2013, 09:36 AM
A garage seems like the perfect place for a pellet or corn stove.
Old January 12th, 2013, 04:18 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I had a large pellet stove in my 40 x 50 garage. Took it a bit to warm the place up, but did do the trick. I have moved the stove to the wood shed, and a pellet furnace will be installed when I get back from vacation.
Nice part is the new furnaces have an inverter built in, so when the power dumps, it can be run on a deep cycle battery. The main blower won't but the smaller back up will push some air.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
heater
The "Increase your heater output" thread Overlander Defender Technical Discussions 25 February 28th, 2012 06:42 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
Garage Cleaning - Everything Must Go!! m.michaels For Sale - Parts 13 February 7th, 2006 03:02 PM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
