Galvanizing Questions - Defender Source
Old July 27th, 2011, 01:21 PM
JBinAlabama
john
Series 2A ..more parts on the way
I'm getting ready to do a batch of series parts and just spoke to the rep for Azz Galvanizing.
They are the closest to me.
Basically, they won't to do a tube or box chassis that is not brand new.
In the past they have had some break in half because of the interior rusting and have concluded that is it rusted on the outside the inside is at least 50% worse......which may be true.
The other parts (including the bulkhead) are no problem
Does anyone have any suggestions?
Old July 27th, 2011, 01:50 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will they do it if you sign a waver saying you dont care if it breaks?
Old July 27th, 2011, 02:17 PM
Next best thing is the full POR-15 treatment. You must do exactly as they direct tho, or you won't have good results. That means the Marine Clean wash, the Metal-Ready prep, the POR-15 coating and then the Chassis Black. Do the insides with Waxoyl if you think it will rust in there.
All that should get you a frame that will last quite a while.
Old July 27th, 2011, 02:24 PM
The Dro
Dro
1988 Ninety
X2.
There is also KBS Coating. I've used them in the past and it's very easy to apply.
Old July 27th, 2011, 03:36 PM
JBinAlabama
john
Great Suggestions!
I'm going to try Barry's first!
Hopefully, they will go with it.
The inside of the box beam is the big question though.
I was going to blast the chassis myself but I found a local guy who will do it for "about a hundred.......CASH"
then I have to weld patches in a couple of places and of course the damn rear cross member.
If they wont Galvanize it, I'll put it on my brothers truck (he lives off the beach) up there it wont rust as fast
galvanizing
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
New differential questions... wicks Defender Technical Discussions 15 May 5th, 2004 11:39 PM
galvanizing questions kit Defender Technical Discussions 4 October 21st, 2003 10:31 AM
