Galvanizing-friendly MIG wire. - Defender Source
Old September 18th, 2014, 11:43 AM
oilburner's Avatar
oilburner
JL
large pile of parts
I am going to be spending some quality time with a MIG in the next month. I recall someone (Matt Browne I think) posting about MIG wire that is less prone to reacting when galvanized, so that welding can be better hidden. Anyone recall what type it was? The local welding guys don't have a clue.
Thanks...
JL
JL
Old September 18th, 2014, 11:50 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You need to clean down to clean/bear metal, no such animal as Galvie friendly wire. But I maybe wrong.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 18th, 2014, 11:55 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
ER70S-6 is a good choice.
Beware--the fumes are EXTREMELY toxic---wear a respirator. I have gotten very sick before breathing in a small amount of fumes.
Best choice is to grind entire area off--even so, the Zinc can be drawn into the pool--just not a good combination. Wear the damn respirator.
Old September 18th, 2014, 12:04 PM
er70s6 is standard for mild steel. no wire is going to be better for welding galved metal short of removing the galv from the weld area. not sure what you mean by hiding the weld. short of tig, that is fiction
Old September 18th, 2014, 12:09 PM
You should remove the zinc first as it contaminates the weld. If you must, then you need to have supplied air. Breathing the fumes is a bad thing....
https://www.osha.gov/doc/outreachtra.../weldhlth.html
Old September 18th, 2014, 12:13 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Edit: Sorry, I wasn't clear. I am talking about welding steel before galvanizing, so as to minimize "coating growth", where the zinc gets deposited thicker on top of welds than on the parent metal and makes welds appear even though they are ground flush.
I found Matt's advice in an old thread on here:
"It is still better to use high silicon wire if mig welding as the zinc will have a high build on regular wire....as in if you grind anything flush the weld will show through"
However, everything I found online says to use low silicon wire, or wire that has a similar silicon content to the base metal, since silicon actually attracts zinc and will cause a higher deposition rate on the metal.
http://www.galvanizeit.org/images/up...lded_Areas.pdf
I think Matt may have just gotten in backwards in his post.
I think ER70S-2 or S-3 is likely what I want.
Anyone else have experience with this? Not so much an issue unless you are making butt joints or lap joints that are ground flush.
JL
Old September 18th, 2014, 12:14 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I believe he is talking about welding before galvanizing.
Old September 18th, 2014, 12:18 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I think he means PRIOR to galvanizing, but yes you are correct.
galvanizing
Brand New Lincoln Electric 180 HD MIG Welder - Atlanta - $600 woldd90 The Flea Market 2 June 9th, 2012 08:10 AM
MIG Spool Gun Set Up $700 Wolf Fabrication For Sale - Parts 3 October 20th, 2011 07:59 AM
Where do you buy MIG weld gas in NOVA Firemanshort Misc. Chit-Chat 11 November 5th, 2008 05:30 PM
What is the most road friendly locking diff? rustydefender Defender Technical Discussions 49 February 21st, 2008 11:08 AM
4x4 Friendly Campsites in GA,SC,NC,FL... norros Trips, Trails and Events 3 March 17th, 2005 07:02 PM
