Fuel Tank Question? - Defender Source
Old September 29th, 2011, 07:28 PM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
Fuel Tank Question?
It seems that after 17 years that a 94's tank should need cleaning out.. Is there maintenance for the fuel tank due to sediment? Does anyone do anything? If so, how? Thanks...
1994 D90 #1880
Old September 29th, 2011, 11:20 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Other than taking it off to move the crap out I don't see what you can do.
- Charles Eames
Old September 30th, 2011, 12:50 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
If you drop it, start hosing down the fuel tank skid bolts with liquid wrench penetrating oil well in advance.
Old September 30th, 2011, 10:55 AM
Unless you went wheeling and got muddy water in it or get clogged fuel filters, I don't see it being an issue.
fuel, fuel tank
fuel tank question Jackd Defender Technical Discussions 1 November 15th, 2010 01:31 PM
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
