Fuel Pump Prime? - Defender Source
Old October 26th, 2015, 06:13 PM
RhinoRover's Avatar
RhinoRover
Andy
1986 D110
Fuel Pump Prime?
Just installed a new gas tank and fuel pump into my 110 and a few gallons of gas. Pump comes on for a few seconds in the ignition "on" position and then turns off. However, it sounds like it's running dry and I'm not receiving fuel at the fuel rails. Do I need to prime the pump??
Old October 26th, 2015, 07:06 PM
rover2a's Avatar
rover2a
Gar Hendry
1967 series2a
If it is like my Disco it primes the system and shuts off the engine has to be running for it to run continuously, this will help when trying to measure the fuel pressure at the rail.
fuel
Oil Pump Prime??? Nigel Defender Technical Discussions 8 March 28th, 2011 04:23 PM
Fuel pump no prime? Check the connectors! Neil McCauley Defender Technical Discussions 2 January 12th, 2010 12:53 PM
Dropping gas tank on 110 again, fuel pump does not prime Neil McCauley Defender Technical Discussions 7 October 14th, 2009 10:25 PM
How do you Prime the oil pump?? redrockrover Defender Technical Discussions 2 June 8th, 2009 09:47 AM
Oil pump will not prime... greend90SW Defender Technical Discussions 8 April 13th, 2006 08:46 PM
