fuel injector cross refference - Defender Source
Old March 21st, 2010, 06:17 PM
roverspecialist's Avatar
roverspecialist
VINCENT TORRONE
1997 RANGE ROVER SUPER CHARGED
Location: 11 MARSELLUS PL,GARFIELD,N.J.07026,USA,201-688-004
i was looking for any one who knows which fuel injectors cross over im looking to upgrade to bigger injector.
Old March 21st, 2010, 09:29 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am running the new style bosch injectors, 4-pintel design, that come from the ford mustang. I am using 19lb injectors although I hear some people may be running a little more. I may try a set of 22lb sometime after I get my engine running and chip installed. I am running them right now in my 3.5 RRC, again, 19 lb. Personally, I get the fuly reconditioned ones off ebay for about $120 per set.
Old March 22nd, 2010, 12:13 AM
19lb Mustang 86-93.
Old March 22nd, 2010, 08:05 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I've had great luck with the ones off E-bay from "South Bay Fuel Injector".
She really took the time to make sure the cross references will fit for me, when I called with just this question. She even went to the point that they measured the dimensions as well as resistance range of the injectors.... then did a face-to-face delivery (I don't live too far away.)
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 22nd, 2010, 02:39 PM
grnthng's Avatar
grnthng
Luis A. Costa
'93 Range Rover County LWB
Hi Chris, I also have a 3.5L RR that was converted from carbs and I remember the previous owner telling me that he installed the 14lb inj. during the conversion. He claimed that for this motor it was better to go lower on psi and I could run 87 without knocking or other issues!
I havn't had any problems!
------ Follow up post added March 22nd, 2010 02:46 PM ------
Vinnie, How are you man! Where did you move back to? It's been a while since I've up rt.17.
Are you back at your old place again?
Luis,
Old March 23rd, 2010, 10:18 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I should not have said my 3.5RRC since I put my 3.9 Defender motor into it. I never ran the 19lb injectors in the 3.5. Small point, but worth noting in case there is an issue using them in the 3.5 (I don't know one way or the other). FYI.
fuel
