Front Suspension - Defender Source
Old July 30th, 2004, 10:48 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Front Suspension
Keith just reminded me that I was going to post pictures of the front suspension that I was so content with. I forgot, but here it is. I have had some major issues to work out with the build of this truck but the suspension I am VERY happy with. The best part is this is very easy and a good fab shop could do it for about $100. It cures all the binding issues that the radius arms cause but still lets you cruise quite well in corners with no sway bar. I mounted the arms over the axle because I had room with the coilovers but you could also leave them below for the stock coils. I think it is a great solution that you could do for cheap and it has no ill affects like the "other" solution. All that is left to do is get some very long shocks. I max out every inch of the 14in coilovers very easy. The frame mounts are bone stock. So is the drivers side radius arm so only the other radius arm has been changed.
Dave
PS: There is one pic of the stock one and 2 of the modified one.
ID:	1137   Click image for larger version
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 30th, 2004, 11:48 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Dave
Talk is cheap, post some pics!
Tis
Old July 31st, 2004, 12:34 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Fine! I'll go out tomarrow and max it. Probably break my super high tech tie rod in the process too!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 31st, 2004, 10:25 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Is that tie rod titanium?
Sign me up.
Old July 31st, 2004, 02:01 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Adamanthium
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 31st, 2004, 02:14 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Holly cow.... Who build this tie rod????? How come you didn't go with offset tie rod?
How about some pictures of the upper mounts.
BTW, I'll be in San Diego soon and I'll be staying a few houses away from you Hope we get together for a drink
Also, how much of an exposed rod you have on your front shock?
Old July 31st, 2004, 08:24 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The tie rod was never meant to do any more than get me home from Phoenix. I am in the process of getting it swapped out but times got kinda crazy with me switching jobs and I parked the truck for a while. That tie rod was built by NSO. Nuf said. OK, now I have to get pictures of the upper mounts too
It would be truely awesome to meet you! Call me when you get close. I will PM you my ##
Exposed rod??? Damn, there are kids reading this, keep it clean man.
But seriously, what do you mean?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 1st, 2004, 12:43 AM
redrover
Guest
Posts: n/a
More -more
Old August 1st, 2004, 05:11 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I went out this afternoon and did some poseur shots of the truck. Take a close look at the compressed coilover. I still have a full 3in of uptravel that is not being used. The spring rates and shock charging are too high because I am mounting a winch and bumper on the front that was taken into account on the springs but has not been put on yet. That should take care of the extra travel. And I have a new problem now, a leaking front air locker. Great, now I need to get back out there and pull it apart again.
Yousef,
Here are the upper coil mounts. It is pretty simple. The lower frame mounts bolt into the steering box holes on both sides. Then they go up and bolt into the firewall and around the back of the engine to connect eachother for strenth. On teh V8, you could connect them further forword in the bay but on the TDi there was not enough clearance in my hood to do it. The pics kinda suck, but here you go.
ID:	1142   Click image for larger version
ID:	1144   Click image for larger version
ID:	1146   Click image for larger version
ID:	1148   Click image for larger version
ID:	1150   Click image for larger version
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 1st, 2004, 05:37 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Nice....
Legend in My Own Mind.
Old August 1st, 2004, 10:08 PM
Noah's Avatar
Noah
Noah
95 D90 TDI
man, it must be nice to live somewhere where you can keep your truck that clean.
Old August 1st, 2004, 11:16 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Thanks for the pics Dave! I wondered if that was what had been done...
The truck looks great! Be sure to give a call if you need anything..
Later
Keith
Keith
Big, Red and ... aaa Red..
Old August 2nd, 2004, 08:53 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
looks like your brake line has become a limit strap
Tis
Old August 2nd, 2004, 12:35 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
How about more pictures of the coil over mount. I can see one side is bolted but what about the other end?
How the hell am I going to explain the "exposed rod"? Ok If you look at the picture of your beautiful tie rod, you'll see the shiny rod that's coming out if the shock??? Damn that's even worse. Never mind.
Old August 2nd, 2004, 08:44 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I only show my exposed rod to my wife. But really, it's 6in on the shock.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 26th, 2006, 02:17 AM
sajidd
Sajid Dadabhoy
can someone advise me approx cost involved in having a coilover set up ? what are the advantages ? disadvantages? how is the roaad ride quality? handing? I am interested in this kind of a suspension set up.
Regrds
Sajidd
Old November 26th, 2006, 08:19 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Regrds
Sajidd
Hello,
I think that I am the last one left running coilovers on this site, since Yousef sold his Defender. Thats why you are not getting many replies. Anyway, here's a basic cost breakdown, assuming you are going with one of the reasonably priced shocks (SAW, FOX).
Coilovers: $450 each with springs complete
Mounting: Really depends on if you do it yourself, and I have no idea what fab work goes for in Pakistan! You need a modified lower mount (very simple). And a modified upper mount (kinda difficult do to space restrictions). Its about $300 here for a pro to do it.
Travel: To get the travel out of it you need to modify the front end link system. A common fix for that here is the 3-link which I think is $600 so lets go with that figure.
So, if you just go through normal channels you are looking at $1800 or so.
Advantages: Everything. Seriously, they excel at almost everything. Lighter, more compact, more travel, multiple spring rates, adjustable ride height, and bling. They are great on the street, great in the rocks, great at high speed and great at slow speed (you can adjust when you want the stiffer spring to compress just by turning a nut).
Disadvantages: Price!
I hope this helps. If you want to do some more reading there is a massive amount of info in www.pirate4x4.com Good luck.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 27th, 2006, 01:02 AM
sajidd
Sajid Dadabhoy
Hi David,
For sure the info helps. The cost is within my over all budget but I am not ready to ditch my ARB shocks and springs as they are not even year old. I am however going with some kind of a dual shock system to compliment the current set up.
The shocks that i am considering are Ranchos 9000 series shocks. Perhaps the 9012 or regular 99159/57.
Thanks for your help again.
Sajidd
front suspension
SafariGard 3 link front suspension cdb Defender Technical Discussions 36 June 8th, 2009 08:01 AM
Front suspension troubleshooting... sflash868 Defender Technical Discussions 1 June 5th, 2006 07:22 AM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Sliding down the slippery suspension slope souza Defender Technical Discussions 18 February 3rd, 2005 11:06 PM
» Defender Registry
Rosco
Cal
Roi
Bassi
Add your Defender
