Front Roll Bar Removal - Defender Source
Old November 13th, 2008, 11:59 AM
tallest1
john derosa
95 D90 SW
Wondering if anyone has an opinion on this...
Has anyone ever removed their windscreen roll bar on their SW simply to achieve a cleaner or "stock uk" look? I suppose there would be some prep and paint work to cover the bolt holes. Or, perhaps fabricated caps or body color painted bolts would be a less permanent approach.
Just a thought and curious as to what the nas d-90 community might think of this approach.
~95 D90 SW~
Old November 13th, 2008, 02:41 PM
I plan to have panels tig welded in to fill the holes.
Old November 13th, 2008, 03:19 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
The holes in the roof are not that big but if I remember correct the ones in the front fender are rather large and would require a patch, plate or new fender to look decent.
Old November 13th, 2008, 03:42 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
look at this link: http://www.copleymotorcars.com/nas_d...3.1vo1475.html
made inserts were it was once a roll cage.
keith humphreys
keith . humphreys @ me . com
617 . 308 . 4100
Old November 13th, 2008, 03:56 PM
tallest1
john derosa
95 D90 SW
great input!
keith - can't tell from the pic but are those plates on the fender flush w/ the body?
i haven't taken mine off yet so i think i should do it just to see what the heck it looks like underneath the mounts top and bottom.
it sounds like, based on the comments here, that the fender location has a "rectangular indentation" where a plate can fit into it and the top one is just holes. does this sound correct?
~95 D90 SW~
Old November 13th, 2008, 04:54 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
the plates are slightly above the "body". they look to be "caps". i dont want to pop one off.... just because i didnt put it on and not sure if it comes off or will go back on. (does that make sense?) i will poke around it some more tomorrow when its not raining and dark out.
keith humphreys
617 . 308 . 4100
Old November 13th, 2008, 05:13 PM
rovertrader's Avatar
rovertrader
Dale
Keith- Just replace the outer wings. I did one with a 200 Tdi and a 300 Tdi outer so the vents were on both sides- or just use blanks. You can remove the cage support at the same time for a nice clean look. And remember, from a safety standpoint, the military doesn't use the exocage either.
Old November 13th, 2008, 05:23 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
i hear you. im content with the way it is now. it looks fine to me. if someone wanted to have them replaced i could do that though.
keith humphreys
617 . 308 . 4100
Old November 13th, 2008, 07:34 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
And I will take that front cage off your hand if you want to !
Pat
Kirk Lazarus, Tropic Thunder
roll bar
D-90 Roll Bar Pads roverboy For Sale - Parts 2 November 16th, 2005 10:28 AM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Rear roll bar pendy Wanted 0 June 17th, 2004 01:10 AM
